1 - 6 of 6 Posts
Type-R
Not sure if anyone has done this, but I didn't find any posts to confirm. It appears
that the TL front suspension components are very similar to the TSX. In fact, I bought
a few parts to compare and I've concluded that yes, the TL Brembo calipers can be
installed on the TSX if these parts are also changed (using TL parts):
Knuckles
Splash Shields
Hubs
Rotors
Tie Rod Ends
Brake Lines
Calipers (of course)
I now have all the pieces, but not sure when I'll have time to install them. I'll post
pics when I start working on it.
Posted from an iPhone
No need to use the TL knuckles. You can modify the tsx to take the TL caliper bolts, then use a 5mm spacer and TL rotor.
Type-R
I prefer a factory fit, as opposed to spacers/shims/whatever.
This project might happen this winter if I have time.
1 - 6 of 6 Posts
