1 - 5 of 5 Posts
I've tried asking in the ECU section but didn't get a response so hopefully get a better one here.
I'm helping a mate tune his car and he has Toda A3 cams fitted. It has a horrendous flat spot midway through the rev range on the low cam which makes for poor shifting as it falls into that rev range.
Anyone have a map they'd be willing to share so I can compare it to the one I've done.
The Turnpike Bully
What other mods does your friend have, i have the Toda A3 cams in my setup but the map i have is tuned will all of the other mods i have. Plus i have bigger injectors, if you want it i can send it to you. All i have to say is use it at your own risk, the map is made for my car and it runs fine, but i don't know about other cars. So if you use it and something happens, don't pm me like WTF. Use it at your own risk.
since u are from UK, the best option is to go talk with CPL racing. they work alot with hondata and toda products
They don't share maps though.
Did you get my PM mate?
1 - 5 of 5 Posts
