1 - 2 of 2 Posts
TODA question....PLEASE HELP!!!!!
I am considering buying the TODA race package from another member but i have a problem First, is it possible to switch out ECU's and if so how do i do it? 2nd, if it is possible Can i run the TODA program on my car with out the cams(cant afford install right away) or will it cause damage? Also, is it possible to put the cams and valve springs in without any reflash or will that cause damage? Any info would be great or if you have any other ideas i'd appreciate the input.
-Mark
Also anyone that has the package, what did you pay for install of the cams and valve springs? Thanks
1 - 2 of 2 Posts
