1 - 20 of 31 Posts
· K20
I already searched but i just want to know from the owners of these cams or people that would know. which one they think is better and makes more power? :thumbsup:
· Registered
The Toda cams are going to make more power, the question is, is it worth the extra money.
· Registered
RSX8600 said:
Thats what i thought but wasn't sure. Now if you have hondata u would have to get your ecu reflashed they say it's a 100 is that true?
With the either set of cams, your gonna want a different flash other then the #4 flash.
· Gothic Hippie RSX tuner?
APEXiTypes said:
...is it worth the extra money.
That seems to be the billion dollar question, doesn't it?
· Tyler
Maybe Type R cams, TODA valvesprings, and the Type R reflash? Or K-Pro and have fun tunig it yourself:) I wonder how well that stuff works with 91 octane. I ain't shelling out the extra $$ to buy higher octane gas all the time....hell 91 is about $2.10 a gallon here right now:jigglemad:
· Registered
2.10 that's cheap man. Our (Nor cal) regular 87 is 2.19 right now :( I have to pump gas for $2.39 a gallon (91 octane). Sux but oh well...it's life.
If I had the extra cash I'd definantly go Toda over the Type R because they will make more power. Depends on how JDM you are and what your overall goals are for the car.
· K20
Discussion Starter · #8 ·
Seems like toda would be better than the type-r cams. Now do i still need to get valve springs even though i have 03 which comes with the s2k valve springs? And these cams start vtec at 3900 and redline at 9000 right?
· Registered
yes you need the valvesprings still. if you got the R cams, you wouldnt. the more aggressive profile of the Toda's require Toda springs.
· K20
Discussion Starter · #10 ·
Yeah thats what i thought. Damn i wonder which one will be better i just havn't seen too many people with type-r cams that post numbers or show time slips from the track.
· K20
Discussion Starter · #13 ·
Think type-r cams is the best way to go and bang for the buck. Toda might make a lil more but not worth the money as i saw when i searched some more. Well it should be the same as long as u got the parts to keep it save like the valve springs.
· Registered
:iamwiths:
i'm going type R b/c they can be had for MUCH less than todas. they are only shy a few ponies from the todas. the few extra HP is not worth alll the extra $$$.
· Registered
budz said:
With the money you save going with with the type r cams and flash, you can buy a type r intake manifold and better tires.
but where does this logic stop?
with the money you saved from not buying the rsx-s you can get a srt-4 into high 12s....
see what i'm saying? for those that arent going to race all out, Type R will be best, but if you want the most HP, it just gets more and more expensive for less and less HP, so dont skimp now. me personally i want a decently fast daily driver, thus the DCRH isntead of Toda, and Type R cams instead of toda.
· New car again...
Jerry, why not go w/ the ITR cams rather than the Toda's? Like everyone else is saying, the money you would save versus Toda could get you a k-pro and ITR manifold. :driving:
· K20
Discussion Starter · #18 ·
Yeah i been looking at some threads and it's not worth the lil more power. Im most likely going to go with type-r cams/mani/kpro. Hey i thought the type-r cams rev to 9? i know j did, or is it set at 8800 and the tach is off on his car?
· New car again...
Yes, the tach is off by like 200rpms. Both Jeramy and Ramon's car revved to 9 grand, but it was really 8800. :D
1 - 20 of 31 Posts
