Hi, I'm in need of some electrical expertise. I tried to search, but no luck. Member name 'BlackandBlue' seems to know his electrical and I will probably PM if he doesn't see this, but it's open to anyone.
I am looking to add a toggle switch to my reverse lights with this functionality in mind: Reverse lights works when in trans is in reverse OR when I use the toggle. I don't want people to misunderstand and think I'm trying to disable the reverse lights while in reverse.
I just don't want to fry anything or hurt the car.
Given that, can I splice in a toggle that would be left off usually and then switched on (basically just bypassing the back-up light switch) when I want to use the reverse lights?
My worry is that I would freak out the ECU if I'm driving forward and suddenly the ECU thinks I'm in reverse. As far as I can tell, the RSX's wiring wouldn't care, but that's why I ask.
Expertise is appreciated. Thank you.
