1 - 20 of 75 Posts
Killing Time Cult
Feel free to add on to this list, I will update.
Suspension
* Tire Lug Nuts 80 ft/lbs
Front:
* 12mm top nut (1) 33ft/lbs
* 10mm Strut tower Flange Bolts (3) 33 ft/lbs
* 16mm damper pinch bolts (2) 115ft/lbs
* 10mm tie rod nut (1) 32ft/lbs
* brake hose bracket (1) 16ft/lbs
* wheel sensor harness bracket (1) 7.2ft/lbs
* Axle nut 134 ft/lbs
Rear
* 10mm top nut 22ft/lbs
* 10mm strut tower top nuts (2) 43ft/lbs
* 12mm damper bottom bolt 45ft/lbs
Rear Camber Arm
* 12mm outter bolt 43ft/lbs
* 12mm inner bolt (2) 43ft/lbs
* 8mm wheel sensor harness bracket 16ft/lbs
Rear Tie Bar
* 12mm inner bolt 43ft/lbs
Sway Bars
Front
* 10mm top end link bolt [to bar] 28ft/lbs
* 10mm bottom end link bolt [to car] 29ft/lbs
* 10mm bracket bolt (2) 29ft/lbs
Rear
* 8mm bracket bolt (2) 16ft/lbs
Engine
Cylinder Head
* Valve Cover (6) 7ft/lbs
* Valve Locknut 14ft/lbs
* Spark Plugs (4) 17ft/lbs
Subframe and Mounts
* Upper Pass Engine mount Flange Nut 40 ft/lbs
* Rear Engine Mount 43 ft/lbs
* Front Engine Mount 47 ft/lbs
* Transmission Engine Mount 40 ft/lbs
* 14mm subframe bolts (4) 76ft/lbs
Oil Change
* Oil Drain Plug: 29ft/lbs (33 ft/lbs Base models and EP3)
* Oil filter: 8.7ft/lbs
* Oil Pan: 8.7ft/lbs
Transmission
* Drain plug: 29ft*lbs
* Filler plug: 33ft*lbs
* Flywheel cover: 9ft*lbs
* Flywheel: 90ft*lbs
* Pressure Plat/Clutch: 19ft*lbs
Exhaust
* 10mm Header Bolts/Nuts 33 ft/lbs
* 8mm Header to Downpipe spring nut 16 ft/lbs
* 10mm exhaust manifold bracket bolts 33ft/lbs
* O2 sensors 33ft/lbs
* Cat to midpipe nut 25 ft/lbs
* Midpipe to Axel back spring nut 16 ft/lbs
Most transmission torque specs can be found here: http://customdc5.my-php.net/diy/clutch/
OIL
Base and Premium Models
Drain Plug - 33 ft/lbs
Type-S
Drain Plug - 29ft/lbs
You might want to figure out which of those specs is for what model...because some of them vary...as shown above.
When I have some time I will try to find some more...
Killing Time Cult
Discussion Starter #18
OIL
Type-S
You might want to figure out which of those specs is for what model...because show of them vary...as shown above.
Updated! Thanks man:thumbsup::giggity:
How do I RSX?
Sticky x 6 :thumbsup: This is going to help a lot of people out man, great work. I printed this out and threw it in my tool box. ^_^
Killing Time Cult
Discussion Starter #20
Thanks I got 98% of it from other people/sites. There are two sites with a list similar to this, but I know that we dont have one so.....
1 - 20 of 75 Posts
