601 - 620 of 657 Posts
Spooning on you!
anybody ever install a rear rigid collar kit? bought a spoon rear kit and wanted to hear peoples opinions.
heres a pic from pbir 2 weeks ago
Turn or burn
Anyone have recommendations on drop in oil pan baffles? I was looking into the circuit hero or the CCW ones.
Hey guys could use some help!
Last week I was just testing out a new setup at cayuga.
10k Front springs
20k rear springs
Ktuned k2 circuit dampers
22m rear bar
15mm front bar
Buddyclub RCA
Tegiwa Steering rack riser. FINALLY my tie rod angles and lower control arm angles are all in the right place. The car is 2 inches lower than stock in the front
The rear is 1 inch lower than stock.
255/40/17 Pirelli Trofeo R tires. So the car is handling awesome except for when I hit the gas. As soon as I'm exiting a corner (or hitting a bump now that I think of it) the car starts oscillating? Very difficult to describe. I found a video on youtube where the CIVIC is doing the exact same thing that my car is doing when I hit the gas coming out of a corner. Any thoughts? I havent put much thought into the rear suspension just yet, but I assumed I wouldn't have a problem because of the ride height.
https://www.youtube.com/watch?v=4atnRRFq-OE
Look at the civic in the video and tell me what you think! thanks in advance boys! I feel like as soon as I figure this out, the car will be FLYING
I had one in the Circuit Hero design. I'd say don't bother as I was seeing oil pressure drop from 8 bar to 3 bar while in turns, and sometimes as low as 2 bar. Just spend the money and get the Mugen pan.
Your problem is the valving is off on your suspension. Try a tire with less grip and see if the problem goes away.
I have a 225/45/17 hankook rs3 I'll see if that helps. So you think it could just be too much front grip? it makes sense, I also forgot to say I was fixing my exhaust the night before and never ended up connecting the front sway, so I also had no front sway
Turn or burn
Thank you sir :thumbsup:
Been a year since I last posted here. I ended up going to a Turn2 track day Oct 12, 2018. TSSxRevscene track day May 12, 2019. And Late Apexing track day June 5 of this year. All with my trusty 06 RSX-S at The Ridge.
I was hooked after the first track day even while driving my car a couple laps out on Pacific Raceways, it wasn’t anything like the full track day experience. I’m going back in the late spring to try and go sub 2.
Fat Free
What was your best time at the Ridge? I think the best I did on the RSX was a 2:06, but thats very much driver limited... about 5 seconds faster on my miata..
2:02x... on 200tw RE71R street tires, Carbotech XP8 no BBK, base cal, and no aero. Search Antiherodc5 on YouTube for that lap. Somehow I forgot to tap start record on Harry’s lap timer but I have the GoPro footage.
The car definitely has more in it.
Fat Free
looking pretty good, similar to what my mods were except you have some real pads
here's my miata, I miss VTEC...
https://youtu.be/-TMgUlHRbYI
Your Miata looks so nimble out there. My goal is to break 2:00 without aero and R-compounds, then I’d be happy and can go boost without feeling guiltily like using a cheat code.
I really need to get the camber even from Left to Right and add more, alignment is a little off, I’m rubbing my fenders still, motor is a little tired at 194k and I still need a tune.
Fat Free
that was my plan too but then I got a deal I couldn't pass up, so I'll have boost for next season... just gotta figure out cooling...
also these days there isn't much difference between 200tw tires and r-comps. I only dropped about .5 sec going from RS4's to R888R's, and I think even that was more due to my driving than the tire. and something like the RE71R is actually faster than most r-comps.
Didn’t you have a Civic Si too?
I saw one video where a guy shaved off 2 full seconds from going 200tw to R-comps and then later he shaved off another 2!
With aero, bbk with more aggressive pads, weight reduction, a bucket seat (still sliding around in the stock leather seat), and stiffer coils since I have a ton of body lean with the Progress coilovers, I can only hope this chassis goes quicker and quicker.
Waifu Deluxe
Autocross went great last Sunday, possibly 4th in points out of 28 now.
Travelling up to Toledo Sunday to co-drive my friends NA Miata on Sunday. Haven't really driven a RWD car with any sort of effort. Really looking forward to it.
Fat Free
I had one as a daily for a bit, so no track time. someone not obeying stop signs put an end to the civic tho...
the current 200tw tires? or 200tw tires of like 5 years ago? or maybe it was a particularly sh*tty 200tw tire...? But you have RE71R's which are one of the best. only way you're shaving 2 seconds off that is going to something with no tread.
a bucket seat will make a huge difference, you'll prolly be able to go sub 2 just from that...
Dang. Can’t say I’m not a victim of dumb drivers either.
It was a S2K guy with Falken rt615 I believe. He also had full aero though.
Haha I’m not that confident I can shave 2secs with just a seat. Next summer I should get a tune done and a new set of pads. Debating from going from XP8s to XP10 or Club Racers.. they’re very similar specs. Maybe upgrade the coilovers too if funds are there. I read your FA 500 review and I’m debating on an entry custom track coilover.
Fat Free
I can see that with the rt615... even the newest version of that tire is a bit off pace off the current offerings. it makes for a good drift tire in pro drifting and thats really the main reason its still around
make sure to get a high enough rear spring rate, I made the mistake of going to soft and the car was always kinda understeery...
