1 - 20 of 137 Posts
Ur Post Count Means Nada!
Q_Q
heres some good info too
Code:
6-Speed Manual Gear Ratios
          RSX Type-S   TSX      DC5R
1st gear    3.267      3.267    3.266
2nd gear    2.130      1.880    2.130
3rd gear    1.517      1.355    1.517
4th gear    1.147      1.028    1.212
5th gear    0.921      0.825    0.972
6th gear    0.738      0.659    0.780
Reverse     3.583      3.583    3.583
FD Ratio    4.389      4.760    4.764
7900rpm Redline Used; 7900rpm Shift RPM Used
I used an 80mph highway cruise speed since thats where we really want it to matter.
Graph #1) Type S Gear Ratio's & FD 4.389
Graph #2) Type S Gear Ratio's & ITR FD 4.764
Graph #3) Type S Gear Ratio's & ATS FD 5.062
Graph #4) Type S Gear Ratio's 1st-5th; TSX 6th Gear Ratio & Type S FD 4.389
Graph #5) Type S Gear Ratio's 1st-5th; TSX 6th Gear Ratio & ITR FD 4.764
Graph #6) Type S Gear Ratio's 1st-5th; TSX 6th Gear Ratio & ATS FD 5.062
Graph #1
Graph #2
Graph #3
Graph #4
Graph #5
Graph #6
There you go boys.
-Jalal
:lurk:
Didn't see info for the auto transmission, but was able to find in elsewhere. Thought I'd share it with you auto guys in case you were wondering like I was.
RSX Automatic
5-Speed automatic with Sequential SportShift and GradeLogic Control
Gear ratios :)1). . . . . . . . . . . . . . . . . . . . . . . . . . RSX Automatic
1st . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.68
2nd. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1,50
3rd . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.98
4th . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.73
5th . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.57
Reverse . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.00
Final Drive . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.56
Mostly stock, Mostly
The following chart is for 02-04 RSX-S and 05-06 RSX-S with standard final drive. It shows the effects that tire size has on speed and shift points for each gear. The first column is for stock tires. Shift point is 8300 rpm. I put this together to see what effect different size drag tires would have on shift points and speed.
02-04-----RSX-S-----Tire-------02 stock---BFG DR----BFG DR----BFG DR----Hoosier-DR---M H slick---05 stock
-------------------------size---205/55/16-205/50/15-205/40/17-225/50/15-225/50/15-8.5/24.5/15-215/45/17
-----------------------diameter------24.9------23.1-------23.5-------23.9--------24.2----------24.5----------24.6
-------------RPM-------DROP-------MPH------MPH--------MPH-------MPH--------MPH---------MPH-----------MPH
1st---------8,300------------------42.88-----39.78------40.47-----41.16------41.67--------42.19---------42.36
2nd--------8,300-----5,411------65.77-----61.01------62.07------63.13------63.92-------64.71---------64.98
3rd---------8,300-----5,911------92.34-----85.67-------87.15-----88.64-----89.75--------90.86--------91.23
4th---------8,300-----6,276-----122.13---113.30------115.27---117.23----118.70-------120.17-----120.66
5th---------8,300-----6,665-----152.10---141.11------143.55---145.99----147.83-------149.66-----150.27
6th---------8,300-----6,651-----189.82---176.10------179.15---182.20----184.48-------186.77-----187.53
05-06--RSX-S----------Tire-------02 stock---BFG DR---BFG DR----BFG DR----Hoosier DR---M H slick----05 stock
-----------------------diameter------24.9------23.1-------23.5--------23.9---------24.2-----------24.5-----------24.6
--------------RPM------DROP-------MPH-------MPH-------MPH---------MPH--------MPH---------MPH------------MPH
1st------\---8,300-----------------39.50------36.64------37.28-------37.91------38.39-------38.86---------39.02
2nd---------8,300-----5,411-----60.58------56.20------57.17-------58.15------58.88-------59.61---------59.85
3rd---------8,300------5,911-----85.06------78.91------80.28-------81.64------82.67-------83.69--------84.03
4th---------8,300------6,276----112.50-----104.36-----106.17----107.98-----109.33-----110.69------111.14
5th---------8,300------6,665----140.10-----129.97-----132.22----134.47-----136.16-----137.85------138.41
6th---------8,300------6,651----174.84-----162.20-----165.01----167.82-----169.93-----172.03------172.74
luvmyrsx
Dont Push That Button....
Ok, this is good info... question though. The Final Drive kits you can buy..... what do those do? I do a lot of highway driving and was looking at something to get me better gas mileage... so would a 5.?? ratio be better for me then a 4.?? ratio?
The higher the ratio, the higher the top speed? Or lower top speed?
I know like on a four-wheeler when you increase the rear teeth on the sprocket you gain acceleration and lose top speed, but if you decrease the teeth you lose acceleration and gain top speed, and the opposite for the front....
Internet Crack Dealer
the lower the final drive (like a 4.0) the higher the top speed. The higher the final driver (like a 5.0) the lower the top speed. The lower the final drive it makes the gears longer. So if you are looking for improved gas mileage then you need to go with a lower final drive. In an RSX you can change to a 4.0 final drive and a TSX 6th gear you can go 80mph without breaking 3000rpm. I am not sure if that is good or bad but we are going to test it in a few.
Discussion Starter · #20 ·
Chris, the lowest gear ratio is now found in the '08+ Accord 5th gear. Even lower than the TSX/Si 6th gear.
0.647 compared to 0.659
-Jalal
1 - 20 of 137 Posts
