1 - 20 of 21 Posts
ok so i just received my wing from trimking1 today
paint matched perfectly
i take out wing everythings fine
i place it on my car just to get a lil preview
its hawt
ill post pics soon
anyways, i want to install it
hardware it came with:::
(1) 4 screws/washer thingies
(2) Plastic Velvet thing
I placed the wing on the bottom and peeped from the bottom through the oem wing holes to see if it matched
it doesnt really match up
i need some help
someone that has had expereince with trimking1 spoilers please help
thanks guys, new clubrsx layout is fat
-jon
got it for 178 shipped
but i still cant install it
someone please post that has installed a TRIMKING1 spoiler
-jon
Drill holes
I got the same wing from the same guy and they fit great in the oem holes. They are on the hatch there should be some circles on the inside just take a 1/4 drill bit and drill them out. then place the wing on the other side and screw them in. All done.
:wavey:
-jon
:wavey:
can you give more details?
there were holes in the spoiler already on the bottom,
it looks like they were supposed to fit perfectly in the oem wing holes
i put the wing on there and i couldnt get the holes to match up perfectly
waht did you do with the lil velvet sticky pad thingymabob?
-jon
I stuck the pads on the bottom of the spoiler and then i just drilled the oem holes I made them big enough for any play with the screws it takes a little of adjustment but should go right inuse a light it helps.
-jon
Discussion Starter · #10 ·
so put the stickers on the bottom of the wing, drill the holes, and then hope they fit?
yup they should fit i have installed two spoilers from this guy and both have fit great.
Discussion Starter · #14 ·
so lemme recap:
stick the velvet stickies to the bottom of the spoiler
drill the 4 holes (2 on each side) what diameter?
then screw them in through the bottom
thanks for the help guys, im a noobie
jon
I drill from the top using the supplied T-stripe thing. The hole I drilled did not match the OEM marks perfectrly. If you already have holes and they don't match, just make the hole a big bigger.
Discussion Starter · #16 ·
so your saying i should drill the holes into the hatch? or into the wing
i was thinking i drill the holes into the wing to match up with the holes in the hatch from the oem wing :confused:
Discussion Starter · #17 ·
email from RON @ Trimking1
Hi
All you need to do is;
-Install one screw into the spoiler throught the hatch.
-Do not tighten
-The spoiler is flexible so you can move the spoiler to the holes till they line
up and then screw them
-Do this one hole at a time and you will be fine.
-If you have a pointed object you can put through the hole this will help pull
the spoiler to where you want it.
We have sold alot of these spoilers as well as installed them and it works
fine.
If you have any more questions or concerns feel free to call our toll free
number 877 230 1192 or email us.
The rubber pads you stick to the bottom of the spoiler.
does he mean the rubber pads are supposed to stay underneath the spoiler when i put it in??? omgwtfbbq!
yeah, those pads go on the bottom of the spoiler, keeps it from rubbing the paint on paint as well as sealing it so no water gets in. There are hole marks in the hatch for the OEM spoiler I started from under and drilled to break through to the top, then came down to finish the hole. This way if the paint cracks or I get jaggies its all on the inside.
Make sure the inside of your wing is clear of fiberglass so the bolts go all the way in.. I had to re-tap mine.
You should have gotten an instruction packet with the spoiler that tells you what size to make the holes. If not take some drill bits and match it up to the screw then go a size bigger and you should be fine.
the92pheish said:
so lemme recap:
jon
Discussion Starter · #20 ·
yah i got directions for the holes so nevermind that q'
so the rubber pads should go on the bottom of the spoiler? i put it on like that - looks retarded - you can clearly see the rubber pad
rsxtc said to put it on without the rubber pads
waht do you guys say
1 - 20 of 21 Posts
