1 - 20 of 26 Posts
· N/A to go please...
Did anybody else find this??
My A/F is fairly flat until it hits 7k RPM, then it spikes or dips sharply. At first I thought this might be the 'open loop' bug Conrad found, but the same thing is happening with 1.0.15. I add a bit of fuel, or take a bit away and it has no real effect. Then Wham! Suddenly it spikes the other way after changing the fuel values by 10-15 units. I can have my A/F above 7k RPM in the mid 12s, or at 14.5, but not at 13.2 where I want it.
Any ideas? Thanks!
Peace
WhiZ
· K series tuning liberator
well, from what i understand....when tuning fuel, one increment is one percent fuel...so 15 increments would be 15% more fuel, or 15% less depending on if you are going down or up.
Maybe try less of a jump in fuel....try the middle of the road and see if that gets you closer to your target AF ratio. Then slowly work up or down depending on what the outcome was.
Discussion Starter · #3 · (Edited)
Here's an example of what I'm talking about. Notice the sudden dip after 7k
Peace
WhiZ
teamxrsx, thanks I've already tried that. When I say 15 units of fuel, I mean literally 15 units. Going from 1590 to 1575, which is like less than .1%
Peace
WhiZ
i would keep trying slowly to get that AF ratio up.....
This may sound stupid, but are you tuning in open loop?
Peace
WhiZ
AH...i c....mis-understood ya.. WOW>..thats a big jump for only a .1% change in fuel value.
Here's one going the other way. I didn't get that much above 7k, but you can still see the sudden spike. I think the total difference in fuel units at the 7k and above values was around 50 between the two runs. Like I said, there seems to be a 'threshold'. Go above it, and I'm too rich. Go below it and I'm too lean. Can't seem to find a happy medium.
Everything before 7k stays about the same.
Peace
WhiZ
Discussion Starter · #8 ·
Trying!! :)
According to the log I am... Like I said, I thought this might be the bug conrad found, but it's still happening in 1.0.15.
Thanks for your help!
Peace
WhiZ
Discussion Starter · #9 ·
Well, by the time it finally goes the other way, I've changed it a total 45-60 units. In this case, I was running too rich (12.5 A/F) above 7k using around 1650 units of fuel at 872 mBar. I decrease 872+ mBar values at 7k+ by 15-20 units, but with no change to A/F. Another 15-20, no change. Another 15-20, and I'm at 1595 units of fuel at 872 mBar at 7k RPM but then I spike to 14+ A/F.
Very frustrating! I suppose I could use simple math to say that it should be at 1625 units at 872mBar at 7k, (and adjust the greater mBar, RPM values as well) but why doesn't the log reflect this properly??
Very frustrating. :firemad:
Oh well, I'll get it figured. :)
Peace
WhiZ
· ECU Tuner
WhiZ said:
Trying!! :)
That's unrelated to what I found.
I suppose you have a whole library of graph templates just as I have. Did you view that nasty dip/spike with some other templates to see if some other variable changes values there?
Discussion Starter · #11 ·
Not yet, but I guess that's the next logical step. :)
Peace
WhiZ
make sure you manually place the ECU in open loop(using the disable closed loop function)...then do your tuning...you never know.
Keep working on it in open loop and tell us what you found.
· San Diego OG RSX
I'll bet money that AFCMD changes there too. It must have something to do with that V2...but im not too sure.
Discussion Starter · #16 ·
Todd said:
What are your cams doing at that point? They should probably be coming back down to 30deg or so around 7k.
Yup, that's exactly where they are. No sudden jerks or changes on the cam angles... I can't find a single other thing that changes significantly at 7k.
Oh well, I'll keep at it. Thanks for the help guys.
Peace
WhiZ
· ECU Tuner
WhiZ, can you post an entire datalog. I'd like to take a closer look at that spike.
Discussion Starter · #19 ·
Veilside02 said:
what happines to your car when it goes over 7k, does it stop reving, or does it lose power?????Thanks-Brandon
No, that's the other weird thing... Car seems to be pulling fine right up to redline. It's just the A/F goes nuts.
Peace
WhiZ
Discussion Starter · #20 ·
Conrad, here's the one with the 'dip', but I'm having trouble finding the spike one, and it was the only real spike I had. I have other dip ones if you want. I dump my datalogs to my desktop to keep the notebook easier to organize, and I may have lost that one. :firemad:
Peace
WhiZ
1 - 20 of 26 Posts
