It's in the vehicles for sale but I just noticed a k series swaps section...noticed a few on here from k20. for those guys... :wavey:
Here's the details:
More pictures can be found at:
http://hondamarketplace.com/zerothread?id=1756475
DYNO SHEET:
http://www.we-todd-did-racing....x.jpg
http://www.k20a.org/forum/showthread.php?t=10998
Engine bay:
-'04 k24a2 completely stock motor
-'04 EP3 Si
-Type-R LSD
-Type-S flywheel
-Type-R clutch
-HASPORT mounts
-Metal shifter bushings
-AEM FPR with Steel braded lines
-Walboro 225lb fuel pump
-SSR budget header with 2.5" collector
-Apexi WS 60mm exhaust with test pipe
-Type-S shifter with B&M short shifter installed
Engine Management:
-Hondata Kpro ECU
Suspension:
-KYB AGX 4 way adjustable struts
-H&R Sport springs
-Brand new tie rod ends and front upper control arms
-Full '00 SI brake swap
-Integra brake booster and master cylinder
-Integra 40/40 prop valve
-Brand new brake lines
-Type-R rear sway bar
-Rear GSR lower control arms
-ASR rear subframe reinforcement kit
Here's the details:
DYNO SHEET:
Engine bay:
-'04 EP3 Si
-Type-R LSD
-Type-S flywheel
-Type-R clutch
-HASPORT mounts
Engine Management:
-Hondata Kpro ECU
Suspension:
-H&R Sport springs
