1 - 20 of 31 Posts
I know that XCLUSIV_1 has posted on his profile that he plans on doing this mod. I was wondering if anyone knows if the mirror housing will fit the RSX and if there are any other problems with installation of these. I would want them to be heated so I might have to order from Canada, or are they heated on '04 TSX now?
I think those mirrors would look pretty good! :thumbsup:
700p LTR TWS .308
they will fit with slight adjustment to the rubber seals, but that's not the hard part. The pain is getting all the wiring to work with the turn signals and running those wires through the car.
actually the only hard part is getting the mirror and making it fir...it might be a little off (maybe)...as i measured it should be a direct bolt on...as for the turn signals...those are easy to hard wire...its the same way u would install the jdm side markers...just hard wire it to the blinkers...as for the heated mirrors...yes the 04 rsx & tsx come w/ heated mirrors...it should not be hard to hook up this option b/c we can add the relay and stuff for heated mirrors.... @ this point i have everyting mapped out, i just need the mirrors!!!! i also have a back up plan that i am working on too....i am going to put a strip of clear led's into the rsx mirror and wire it to the blinkers....
R.I.P Turbo'ed base auto
There he is, thats the guy i was talking about. :wavey:
700p LTR TWS .308
the main reason that it wont be a problem is becaues the mirror hangs off our door anyways (open your door and you'll see what I mean. That rubber grommet thingy is what you'll have to alter though.
These mirrors should have came w/ the car originally.... :thumbsup:
Premium Member
ONe of the admin's on the board actually did try this..........i talked to him tonight..........it will not work............the high of the black piece on ours does not match the hight of the tsx mirror where they meet..............actually it might work but won't look right or flow good.
o.k. does anyone know where i could get a led strip....i need like 6 leds in a straight line already connected to each other....6 for the drivers side mirror and 6 for the paasenger side mirror!!!!
1 - 20 of 31 Posts
