1 - 20 of 24 Posts
JDM JRSC DC5-R
Hey guys,
I bought a s/h JRSC kit off a DC5 forum member.
Kit came with 3.4" pulley, CT Auto tensioner, 650cc RC injectors....
I think its a CTAT anyhow, looks like this...
I need a little help as the kit is/was missing a few items.
The guy cannot get to the car to retrieve the items either as he wrecked it and is now scrap!
It hasn't come with any of support brace parts!!
Just wondering if anyone can point me in the right direction for replacements (not Jacksons extortionate prices!!) or if anyone is selling one.
Or, is it possible to fab my own? Any dimensions?
Also, he has sent me the RC injectors, but no clips.
I have some new RC type clips, but i don't want to cut/solder my OEM loom.
Can i de-pin the OEM connectors and re-make them using the RC clips?
Or am i destined to have to cut them?
I have ordered all new nuts, bolts, gaskets, hoses, clamps etc for the install.
I also want to renew the belt as it's looking tired.
It is a Goodyear Gatorback 7PK1970 (P/no. 4070775)
Any idea where I can get a replacement at a reasonable cost?
All/any help is greatly appreciated.
Stoo
Brent
for the support bracket
052-274 x 2
052-297 x 4
052-153 x 1
052-291 x 1
052-290 x1
052-289 x 1
051-727 x 1
051-505 x 1
http://www.supercharger.com/Shop/ViewProducts.aspx?PlateIndexID=81939
http://www.supercharger.com/Shop/ViewProducts.aspx?PlateIndexID=85394
are all the part numbers for the manifold support bracket (near 200$ just for mounting support supplies :( ). you can make your own I had to as I was in the same situation as you when I bought my kit used. I would recommend getting a jmerc tensioner.
JDM JRSC DC5-R
Yeah i got all the P/no's off the Jackson site!!
I almost sh1t a kidney when i saw the cost!!
You got any pics of your fab'd one?? Any measurements?
CTAT no good??
I fab'd the lower support myself, its not a big deal. also u can buy a set of rc adaptorclips from ebay or so. Also u can get a contitech 7pk1970 from any local machine shop.
JDM JRSC DC5-R
Discussion Starter #6
Any pictures of the fab?
I'm in the uk btw so can't get a belt here so easy.
I have the adapter clips already! Just not Plug an play and I don't want to cut the loom.
JDM JRSC DC5-R
Discussion Starter #7
Only one that I have that shows what I did to the bottom manifold plate and ran a piece of alum from there to the block and bolted in place. Its not pretty but it works very well
Thanks. I'll see what I can fab.
Stoo
look here: http://www.ecrater.co.uk/p/6641667/mitsuboshi-v-ribbed-drive-belt-7pk1970
but basicly any carshop, garage or whatever its called can get it.
clips like this? http://cgi.ebay.com/ebaymotors/HONDA-ACURA-INJECTOR-CLIP-ADAPTERS-RC-PRECISION-_W0QQcmdZViewItemQQhashZitem27b563f631QQitemZ170546951729QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
for the pics, i can make some later on.
edit: http://img203.imageshack.us/img203/8696/img1771l.jpg
JDM JRSC DC5-R
Discussion Starter #9
Thanks, but I want a Goodyear gatorback belt.
Struggling to find in the uk.
Those injector clips are ideal, but I already have RC connector blocks and want to re-pin the OEM loom into those. Is it possible?
So u just have the rc connector w/o the wires?! then better to get wires and cut and solder the oem loom.
2
Guest
I believe Summit Racing will ship to by EMS or whatever. Might check out their site. That is where I always get my Gatorbacks.
JDM JRSC DC5-R
Discussion Starter #12
This is pretty much what i have been sent.... x 4
I DO NOT want to cut/splice/solder the original loom!!!!
2
Guest
Well, if that is the case, then you are better off buying some plug-n-play jumpers for your RC injectors. Their website will have dealers.
2
Guest
Give it a shot. You have nothing to lose by trying. Worst that can happen is that the pins don't fit.
JDM JRSC DC5-R
Discussion Starter #16
I have sourced some plug and Play clips now...
Just the belt and Brace to sort now :)
Almost there, then i can fit and wait for MASE to get his A$$ Over for mapping in march :)
Scotty we need more POWER
I definitely want a gatorback.
I'm near Basingstoke.
Blazingsmoke......
Dont suppose you know Tony (TJ) that used to run around in a red Accord Type R?, he works as a mechanic up your way. I know from my old ATR days......
I realize this could be abit like "I live in Australia" -> Oh you dont know Johno do you??
Good luck getting a Gatorback, I searched in vain for weeks in the UK trying to get one, turns out they dont even make them the size I wanted.......ho hum......
Super Moderator
i had a support bracket custom made. No pictures. But just a rectangle chuck of aluminum cut and tapped for the block and a piece measured from under the charger to the square.
1 - 20 of 24 Posts
