1 - 3 of 3 Posts
Ludatic is coming over tomorrow afternoon to check out the interior lights in the RSX to see if it is possible to swap the red to blue or any other color using led's. The question is, can someone with a helms manual copy and post the removal instructions for the guages (speedo, tach, etc.)? I can figure it out myself, but it is very hot out here in the desert, 110+ degrees, so I would rather go out to the car already knowing how to take it off, rather than messing around with it and having a heat stroke. I have no trees for shade:(
Thanks so much:thumbsup:
Dave
remove the 2 platic panels under the steereing column, get a flashlight and a long handled phillips screwdriver. Look up under the dash on either side of the steering columnand you will see 2 screws(1 on each side. Remove these 2 screws, then use the holes to push out on the gauge cluster. Once it pops lose, sit in the driver seat, tilt your wheel all the way down, and slide the cluster out so you can unplug it.
HTH,
Steve
1 - 3 of 3 Posts
