1 - 7 of 7 Posts
· Registered
Want To Buy - Dash and/or Engine Harness(es) for an '03 Base Manual RSX
I am doing an "Auto-to-Manual" Swap on a 2003 Base RSX
I need a base M/T 02-04 engine harness, unmodified/uncut/etc.
also looking for base M/T 02-03 dash/instrument harness unmodified/uncut/etc.
engine harness p/n: 32110-PND-A00
dash harness p/n: 32117-S6M-A00
1) - Is the ENGINE harness necessary, or can I use my BASE engine harness with a slight modification?
SEE REFERENCE : https://youtu.be/kH4oiOgQg-g?t=786
"Aspired Driven" apparently used his Base ENGINE Harness from his AUTOMATIC.
  • He says he " extended his speed sensor wire ", but I am not clear as to exactly where he extended it to so that he could use it . Can anyone clarify ?
  • He says he cut all the sensors on the Automatic Engine Harness ( could these just be taped up and tucked away instead ? )
  • Last thing he said is that he needed to wire the Automatic Engine harness to the reverse lights ( I figure the performance shop should know how to do that ) .
    Can anyone verify what Aspired Driven said, or is there a lot more to it than what he said ?
    See : K Swap Auto to Manual Harness Conversion - VTEC Academy
2) - It appears that an '04 DASH harness would NOT be compatible with my '03.
Can anyone verify ?
If you CLICK HERE, you will see that an '04 M/T Dash Harness is apparently different from that of an M/T '02-'03 RSX.
NOTE:
An 02-03 M/T RSX use a 32117-S6M-A00
Whereas, an '04 M/T RSX uses a PN : 32117-S6M-A01
3) - Are there any other cars ( year and model ) I can get these harnesses out of aside from just an RSX ?
I am in Georgia . Let me know if I can pickup, or what it would cost to ship to me.
· Registered
Hey buddy. IF you get PM's from members with 1-3 posts and they suggest a 3rd party sale with suggesting a weird email with a weird name. Please tell me so I can look into it.
Will do.
Good lookin' out bro.
Just need . . .
  • Dash Harness
  • Engine Harness ? ? ?
  • Rear Mount Bracket
  • 5-Speed Transmission
  • KPRO
And then I should be good to go.
· Registered
Still wanting to buy a " Wire Harness, Instrument - Acura (32117-S6M-A00) ".
This is the wiring for the M/T dashboard .
1) - Is anyone here selling one ?
2) - Is the M/T dashboard harness the same for an 02-03 RSX, a Civi Si or an EP3 ?
· Registered
Oh shoot i didn't see this thread. the only difference from the 02-03 and 04 dash harness is 04 have heated side mirror connection. If you wanted heated side mirrors then go with the 04.
Thanks for the reply.
I already got an '03 M/T dash harness.
Been without heated mirrors in Georgia for 16 years.
I'm good concerning that. (y)
But good for others to know .
1 - 7 of 7 Posts
