1 - 9 of 9 Posts
· Registered
I read that I could remove the rubber weather guard from the high beam and let it dry out.. would this work or is there any other way to remove it?? thanks
· It's just Teflon...
if you dont want to remove the headlights put silica packets in the headlights behind the reflector bowl....you can also run highbeams day and night for 2 weeks. this will only help it a little
· Registered
I fixed this in the past by putting silicone sealant around the headlight seals, after drying the headlight by a fireplace and all the moisture was gone. Took a few days though, you can also bake the headlights at a low temp to get rid of the moisture and separate the lens so you can get a good seal around it.
1 - 9 of 9 Posts
