my 2002 rsx has a low rpm problem, what can it be?
it's at 500 rpm and it shuts off
Could be a lot of things, the easiest first thing to check for is anything going on with your air intake, if it has been plugged, or your throttle body is having issues or any vacuum leaks. After you check that stuff I'd check my fuel system next to see if there is any issues with the pump, injectors ect.
There is a decent chance it is something along those lines but there isn't much info in the post to go off of
Good luck with the issue!
