hey JCL do you notice that the heavier wheels slow you down??? or is the 4-9 lbs not noticable???? does anyone know at what weight you notice the power difference????
There is no specific weight. For rims, you can probably estimate the change in inertia by assuming 2 lbs of change is like adding/removing 3 lbs of static weight in your car, ie. multiply the difference by 1.5, and don't forget to count all 4 rims. This is an estimate, as for 17" OEM rims I estimate it's closer to 1.4, but for my 18" Gram Light 57f's it's more like 1.5. For tires, the ratio is much closer to 2:1, so if each tire were 1 lb heavier than stock, that would be like adding 1*2*4= 8lbs of static weight to your car.
The 17" OEM rims weigh about 20.9 lbs each with stems and balancing weights, but the inertial effect is another ~8.5 lbs. The rim inertia is dependent upon the outer tire diameter.
The 17" OEM 215/45/17 tires filled with air weigh about 21.3 lbs, but the inertial effect is another ~21.5 lbs. Total 'weight' 4*(20.9+8.5+21.3+21.5)= ~289 lbs.
The 18" Gram Light 57f's weight about about 18.3 lbs each with center cap, stems, & balancing weights, but the inertial effect is another ~9.0 lbs. The rim inertia is dependent upon the outer tire diameter.
The 18" Eagle F1-GS-D3 225/35/18's filled with air weigh about 21.6 lbs, but the inertial effect is another ~21.5 lbs. Total 'weight' 4*(18.3+9+21.6+21.5)= ~282 lbs.
So although I went to 18" rims, because I choose light rims/tires I was actually able to shave off the equivalent of 7 lbs. Definitely not worthwhile from solely a cost perspective, but I got much better, wider tires and unique rims in the process.
Note that my 'weights' are only accurate for straight line driving. When turning or hitting a bump, lighter wheels/rims will be more responsive since they have less momentum. And again, I had to estimate those numbers based upon the distribution of material relative to the point of contact with the ground (from the center of the axle), which although I didn't do methodically, should give pretty reasonable results.
