nah, this one guy was talking about type r cams. since most of the people here say it is a worthwhile mod and a lot of the dynos prove it i am convinced. btw, this is the link to the thread... http://www.honda-tech.com/zerothread?id=880601BlackNite said:Maybe they were talking about Type-S cams with Honata flash vs Stock ITR. If so, THEN that statement would be close to accurate. But if you do the same thing with the ITR cams (Hondata flash) then the ITR cams still walk over the Type-S cams/w flash.
That's the same thing I have ran on stock cams, stock tires.Another LeveL DJS said:13.9 seems right with typr R set-up...i have the k20a swap and so far my fastest was a 13.92 with shitty tires...
I understand where you are coming from, but I'm sure you'll always have more HP out of ITR cams than stock Type-S cams given equal conditions. I think your point is that you get HP, but the extra HP is not worth the money correct? I myself am going the ITR route, but my setup will be mild (ITR cams, ITR IM, K-pro with ITR flash.. eventually dyno tuned, S2K springs, RSR exahust). My goal is about 210 WHP with my 18's on. Without changing my header to say the Toda or DC race header, I will be hard pressed to reach my goal that easily with stock cams.JTSmith said:That's the same thing I have ran on stock cams, stock tires.
Notice the guys avatar on honda-tech?
Hapa DC5 said:ha it's u... u may want to explain ur position on type r cams, some of these guys might be too lazy to click the link lol.
Drop in the ITR cams + reflash and see how your times improve. It's hard to compare between cars on the track or the dyno. You need to compare between mods on a single car.JTSmith said:That's the same thing I have ran on stock cams, stock tires.
:iamwiths:Drop in the ITR cams + reflash and see how your times improve. It's hard to compare between cars on the track or the dyno. You need to compare between mods on a single car.
exactlyBlackNite said:I understand where you are coming from, but I'm sure you'll always have more HP out of ITR cams than stock Type-S cams given equal conditions. I think your point is that you get HP, but the extra HP is not worth the money correct?
This is what everybody says. No one really compares a hondata4 setup to an itr cam/reflash setup. Everyone just keeps looking at the numbers from the stock ecu to the itr reflash/itr cams.Glimpse said:Drop in the ITR cams + reflash and see how your times improve. It's hard to compare between cars on the track or the dyno. You need to compare between mods on a single car.
Then compare it against hondata #4.JTSmith said:This is what everybody says. No one really compares a hondata4 setup to an itr cam/reflash setup. Everyone just keeps looking at the numbers from the stock ecu to the itr reflash/itr cams.
We can go back and forth on this forever, but it all boils down to "do you want to spend $400-$500 and a solid afternoon installing them just for a minor gain?"
I'll be glad to race anyone near me(is there anyone near south ga :dontknow: ) that has an itr cam setup, just to prove my point![]()
But wouldn't you expect for someone with say toda c's or crower's big cams to pull on you if you raced? I mean what's the point if it's not noticeable.Glimpse said:Then compare it against hondata #4.
But it's not as simple as two cars racing each other, you know that. There are many other factors at play.
Naturally, big cams will pull on a ITR setup. But how many people are going to sacrifice VTC for Spec C's, or have that kind of money in the first place? Power is an expensive thing.JTSmith said:But wouldn't you expect for someone with say toda c's or crower's big cams to pull on you if you raced? I mean what's the point if it's not noticeable.
Bottom line, I would be pissed if my cammed car couldn't or could barely pull on a stock cammed car.
My bank account says the same thing...My small wallet dictates that I must go the ITR route
