1 - 3 of 3 Posts
· Registered
those wheel thingies on the back end of the camshafts. I can't seem to find it in the service manual. would've expected it to be listed somewhere in Chapter 6. 6-28 lists the specs for the camshaft sprockets but not the pulse plates.
Also, in the NHTSA TSB database the following item appears:
Make : ACURA Model : RSX Year : 2002
Service Bulletin Num : 010702 Date of Bulletin: JUL 01, 2002
NHTSA Item Number: 636793
Component: ENGINE AND ENGINE COOLING:ENGINE
Summary:
SERVICE MANUAL FIX REGARDING TORQUE SPEC FOR CAMSHAFT PULSE PLATE. *TT
sounds like they either left it out or had it wrong! anyone know the answer? thanks
· Registered
Discussion Starter · #2 ·
I got the answer (thanks GreenBean)
29 lb-ft (39 N-m) for the mounting bolts on the pulse plates.
83 lb-ft (113 N-m) for the intake VTC actuator mounting bolt
51 lb-ft (69 N-m) for the exhaust camshaft sprocket mounting bolt
good to know if you install your own camshafts, or you want to make sure your shop gets it right.
1 - 3 of 3 Posts
