1 - 5 of 5 Posts
I want to say that's the switch for the reverse lights, but I am not 100% sure.
I called Acura and they confirmed that it is for the Reverse lights when backing up.
Apparently it is item #6 found at : 2002-2015 Acura Switch Assembly, Back Light (Gray) (Tokai) 28700-PHR-003 | Acura Automotive Parts
Part Number : 28700-PHR-003 ( Back Light Switch Assembly )
They also mentioned that, based on the pictures, that the top-half of the plug appears to be from one of the harnesses.
In other words, what we are seeing in the picture are actually two (2) pieces sandwiched together.
Discussion Starter · #3 · (Edited)
I took apart the plug.
See pics:
QUESTION :
Does this top-half of the plug belong to the Engine Room harness ?
Or does it belong to the Dash harness ?
Or do you run two wires from the M/T tranny to the firewall, and then connect to your A/T shifter wire harness ?
Original Owner
2005 acura rsx type s
1 - 5 of 5 Posts
