1 - 2 of 2 Posts
i-VTEC do you?
is it better to spray soapy water on the vinyl and the light than to jus doin it w/o the soapy water??... and does the vinyl tend to move and slip around when u use the spray technique? would like info and help
<3 Convertibles
I used soapy water on the vinyl just in case I screwed up somehow. It also helps ensure there are no air bubbles in the vinyl, as you push them out toward the edge of the vinyl.
1 - 2 of 2 Posts
