^ Use that link above, they are one of the best companies out there and they have a chat feature that allows you to talk with their experts and they will help you come up with the best item for your car
Mainshaft thrust adjustment
I thought I'd make a little DIY to clarify some of the steps outlined in the helms manual for checking and setting the mainshaft thrust on a 6 speed k-series transmission.
DISCLAIMER
Use this guide at your own risk. I assume no liability for anything that happens...
hey sorry if this was already asked but i couldnt find anything on it... will a new civic si lsd fit in my 03 rsx-s i have the oppertunity to get it very cheap if it will work
Ok so I have a base 05 with a blown trans, I found a cheap accord 5 speed near me. I know the trans mount is different, could I just swap a k20 case on it? If not what mount would I have to use for it to work in the rsx? Thank you very much.
Hello,
I just replaced my clutch/flywheel. There was a 17mm bolt that I believe went through the starter motor that I stripped pretty bad. I was able to remove the bolt, but I want to replace it with a new one. I have searched through many part lists, I am having trouble locating this bolt.
I...
I replaced my my clutch now my car won’t start any ideas? I went back through and checked all wires of damage and made sure they were connected and clean as well as the ground on the bell housing. I tested spark after new plugs and it was good but the car didn’t wanna start. It was trying to...
