1 - 4 of 4 Posts
Finally some go for your show! :)
Add stock tail lights to your list and you seem to be on the right track for a tight car! To answer your question, you may want to e-mail Hondata.
A2 head on a A3 block with an auto? Not sure if it will help you much since the motor will definantly fall out of VTEC range in every gear. It's a lot of money, considering you have to reflash your ECU and everything. I'd look into a 6-spd swap before going with a A2 head. With a 6-spd swap, i/h/e you will run into the high 14s if you're a good driver.
i am not positive but i believe you cannot get any other flash on the auto except the one avaiable because the auto's ecu is a little more complicated
1 - 4 of 4 Posts
