1 - 14 of 14 Posts
OIL 1
>>Typical/Test Data
SAE Grade ASTM# 5W-30
Appearance Visual Amber
API Gravity D-287 34.3
Lbs/Gal Tables 7.106
Specific Gravity @ 15.6/15.6°C D-1298 0.8534
Viscosity @ 100°C D-445 10.61
Viscosity @ 40°C D-445 55.43
Viscosity Index D-2270 185
Pour Point, °C D-97 -48
Flash Point, °C D-92 241
Fire Point, °C D-92 257
TBN D-2896 7.64
CCS Viscosity, cP @ °C D-2602 [email protected]
OIL 2
Kinematic Viscosity @ 100°C, cSt (ASTM D-445) 10.6
Kinematic Viscosity @ 40°C, cSt (ASTM D-445) 57.3
Viscosity Index (ASTM D-2270) 178
CCS Viscosity @ -30°C, cP (ASTM D-2602) 5254
Pour Point °C (°F) (ASTM D-97) -51 (-60)
Flash Point °C (°F) (ASTM D-92) 228 (442)
Four Ball Wear Test (ASTM D-4172B: 40 kgf, 75°C, 1200 rpm, 1 hr), Scar, mm 0.35
Noack Volatility, % weight loss (g/100g) (ASTM D-5800) 6.6
High Temperature/High Shear Viscosity
(ASTM D 4683 @ 150°C, 1.0 X 106 s.-1), cP
3.2
Total Base Number
12.2
OIL 1
>>Typical/Test Data
TBN D-2896 7.64
OIL 2
3.2
Total Base Number
12.2
OIL # 2
BTW where is the four ball wear test for oil # 1?
for one thing it has a really high TBN which i believe means it is a very robust oil that will last a long time. And from looking at how others did in the four ball wear test it seems to have a very short wear scar.
also i looked at the pour point and the flash points but after another look i think i was looking at it wrong.
Discussion Starter #10
Here's the torco race oil specs
Viscosity @ 100°C D-445 11.96
Viscosity @ 40°C D-445 n/a 85.47
Pour Point, °C D-97 -40
Flash Point, °C D-92 203
>>Directions
Follow manufacturer’s fill level requirements. Compatible with other petroleum and synthetic lubricants.
the other is the torco regular synthetic oil
when i said #2 was better that was based on the numbers btw
i didnt just say it was better because i knew it was amsoil
Based on the numbers I believe #2 will protect your motor better. (who am i thought right, lol)
but #1 does look like a very good product.
its a wooden pickle
Where is the best place to buy amsoil at online? I dont know if any part stores around here carry it.
Also, theres a few variations of the 5w-30 grade, any suggestion on the better choice. Done some searching, bet others would like to know too.
Thanks in advance.
1 - 14 of 14 Posts
