1 - 20 of 460 Posts
This is for all the "What turbo should I put on my RSX threads". If anybody wants to add to this to make it the most comprehensive thread on RSX turbo kits, then feel free to do so. Maybe if we get ONE good thread going that we can keep uncluttered then we can get one step closer to a better boost forum.
When looking at turbo kits for the rsx, the first thing in your mind should be "how much power do I want to make?" After you answer this question, you will be better suited to choose which kit you should go with.
This thread contains various dyno plots from boosted vehicles: Boost Dyno Thread Use it to gauge power potential with various mods. Keep in mind that all engines, tuning devices, and dyno measurements are different and are in no way a gaurantee of outcomes, but they can be used to roughly predict output.
Cybernation Motorsports was in the forefront of turbo kit design for the RSX. They offer kits for both the RSX type S and the base model RSX. While the quality of the components in the kit may not be as good as the HKS / Greddy kits, what they lack in craftsmanship, they make up for with upgrade potential. Cybernation kits are available for everything from a street setup containing a T3/T4 combo turbo, to monster race setups with their stage 3 turbo kit containing a 62-1 turbo and a complete internal rebuild of the engine. Many users have found success with their 60-1 turbo and are making 12sec passes with it. Cybernation (CN) kits come with turbo piping, intercooler piping and intercooler, injectors, gauges, an exeternal wastegate, and their Guardian E.I. engine management system that allows the user to install their turbo kit, wire up Guardian, and drive their vehicle relatively safely without having to tune the vehicle. Care should be made to verify that guardian is working for you by dyno testing your car with a wideband 02 to ensure a correct a/f mixture, although many users support its function. Guardian updates are constantly made and revisions are able to be upgraded into the Guardian through your computer.
Full-Race Full-Race is a very well known and respected company amongst participants in various import drag race circuits, producing products deployed by both professional drivers and amateurs alike. Full-Race employs some of the best fabricators in the field, and uses state of the art equipment to produce their wares. They are a full service fabricator, which can produce damn near anything race related, that you may need, from full turbo kits, to custom design intake manifolds.
Regarding K-series equipped vehicles, Full-Race is finishing off the development of top quality kits Produced with the same Materials and workmanship which has made them famous. As with all of their streetable manifolds/downpipes, the K-Series stuff will be produced of the finest grade stainless steel available; Robotically TIG welded, to ensure proper joining off all seams, for guaranteed lifetime service. Full-Race is certainly not your average “one size fits all” manufacturer, so you may request custom changes to your kit, to suit your needs. The equal length manifolds and true merged collectors will help the K-Series enthusiast to achieve his/her goals as efficiently as possible, extracting the most power per pound of boost of any of the available kits.
Full-Race turbo kits are designed for those who are serious about tuning their kits and are not willing to settle for anything less than top quality, as the kits will prove to be some of the highest priced systems available for the K-series family of vehicles, with quality comes a premium.
The Full-Race kits will not include any fuel enrichment devices, so the tuner will need to seek out the engine management system of their choice.
Buy with confidence, as you will certainly not need to “upgrade” any component of the kit in short order.
Greddy kit is a good, well rounded kit featuring a nicely sized turbo designed to produce great gains in the 7-10psi range. It comes with the Greddy E-Manage tuning solution which offers the user a nice preprogramed map for stock boost levels, but the option to tune it yourself and add on further options to tweak your tune. The base kit does not come with an intercooler or blow off valve (BOV), but those are things you can add on at a later date, or purchace the Greddy Intercooler kit, which comes with all the piping and accessories needed to mount the intercooler. The kit does have problems with the oil lines but solutions are becoming available in the form of aftermarket braided oil line kits. Users have had significant gains when switching the e-manage for hondata k-pro.
The HKS kit is relatively new and is still widely unused, partly due to its high cost. Similar to the greddy kit, it is designed for relatively low boost settings with relatively little upgradeablitiy. This kit is very well engineered and setup as a relatively high end solution for lower boost needs. It uses a GT2835 ball-bearing turbo for longer turbo life, an internal wastegate setup, and a HKS SSQV BOV. No fuel / engine management system is supplied, although HKS recomends their own HKS F-con Vpro. Greddy e-manage and Hondata k-pro are alternatives for engine management. An intercooler is available seperately from HKS if you wish to have one and not custom fabricate your own.
RevHard [i do not know enough about the Rev Hard kit to feel comfortable writing anything on it. If somebody with more knowledge would be willing to create a Rev hard writeup, I would appreciate it.]
Putting a turbo system on any car that did not come from the factory designed for Forced Induction (f/i) is never something that should be looked at as being 'easy' or 'cheap'. If you try to make a budget turbo kit and do not make wise decisions regarding your component choices, you will end up dissatisfied. More times than not, the costs required to build your own turbo kit is equal to, or greater than the costs of purchacing a completed kit to begin with. This is in no way meant to throw off people from trying to build their own kit, merely letting them know what they are getting into.
The most important aspect in your turbo kit will be the engine management system that either comes with it or you choose on your own. There is much debate over the available engine management systems, and the important thing is to do your own research and find what you feel works for you given your needs, tuning knowledge, and price range. The ECU and Electronics Forum is a great place to begin researching available tuning options.
If anybody has any information / corrections to make, please feel free to do so... I did this fairly quickly so errors are probably there. Please point them out and we will perfect this thing. Lets make a good thread that can be used to suppress these redundant threads.
Traction is for pussies
i'm going to go ahead and sticky this (and change the thread title)
but i appreciate the great unbiased writeup
please note, i'd like this thread to remain question and clutter free, but if you have any unbiased information to add to this thread about these turbo kits or about another turbo kit, feel free to add it
as i said, the goal is to make this thread as clutter free as possible, so any useless comments or arguments/flame wars will be deleted
that said, i'd love to see reviews of the full-race kit, the one-fab kit, the SCI kit, etc. etc.
if you are going to do a review, please try to keep it in a similar format as Arctic04S's post...tell the pro's and con's of the kit (as everything has pro's and con's)
but Arctic04S, great thread idea... :thumbsup: and +rep for you
Slk-Dc5 said:
i want to build my own turbo kit...but its gunna be hard tryn to figure out wut i all need to do..n which pieces are best....any help...im all ears...
:dontknow:
by build your own turbo kit, do you mean make a manifold and downpipe and then buy a turbo, injectors, fuel management, etc. or do you also want to buy a manifold and downpipe from some company?
After reviewing the sites, it looks like only Cybernation offers a turbo kit for the base Acura RSX 2003 model... It also notes that the kit is not street legal.
Can anyone link me to a few different kits that are street legal for a base Acura RSX 2003?
Thanks a ton. -RSXMidnight03-
there aren't any
On GReddy's site it mentions that many of their kits are CARB 50-State legal. Does that include it's kit for the 02-04 RSX-S? What makes a turbo kit illegal in California? Thanks for the help in advance.
Discussion Starter · #10 ·
I don't think that they have got CARB aproval yet.
And it is illegal in california because it is not CARB approved...
what part of the turbo kit stops it from passing emissions?
and
Many of the kits are covered under CARB E.O. numbers which make them 50-state street legal. - taken from GReddy's site
Discussion Starter · #12 ·
and
the RSX Greddy kit isn't CARB legal yet... they had to resubmit the paperwork and it hasn't gone through yet.
the fact that you are changing the injectors is a large part of the problem with passing carb
MrBurner said:
there aren't any
So I take that as... "No turbo for me unless I upgrade to the S-Type down the road, or never pass emissions testing! LOL" Crap...
:dontknow: What to do... What to do... :dontknow:
there aren't any PERIOD
not for the base or the type s
I have been reading all that I can on FI and I have decided to go with the Greddy kit. The questions I have are..... the kit doesn't come with a BOV and wondering if I need to have it right away? The oil lines are stated as being a concern, so where can I find better ones? Do I need to get gauges right away and if so which ones are essential? Thanks
the greddy kit comes complete. you will probably want a boost gauge as well though. BOV is not necessary either except it sounds awesome ;)
I bought a BOV and flange today and now I am wondering .....Does it matter where I mount it?
Thanks
I'm considering a turbo for my '02 type S and I'm also looking to hear from anyone with the Rev Hard kit or the HKS kit. Preferably someone with dyno stats?
1 - 20 of 460 Posts
