1 - 12 of 12 Posts
I just installed the street version of the JRSC yesterday and it seemed everything was running fine with a little of an idling problem because the throttle body was loose. Today i drove it and it was fine going to school but coming home, it read lean the whole time (WOT). Does anyone have any guesses as to what is going on? I really appreciate the help.
Buttplugs?
a)Your fuel pump may be crapping out on you
b)Your FPR may be loose
c)Clogged injectors
I think this has been covered so try a search on it and see what you come up with. Good luck, buddy.
You really paid for that?
As a quick fix, trying pulling the ECU fuse under the hood. That resets the ECU. That would be the first thing I tried, if it does it again, you have a problem.
Whatever you do, please don't WOT until you can get it fixed!!!!!!!!!!!!!!
The TFI box that ships with the street kit is a piece of junk. For the week that I had the TFI installed, it never worked. Then again, I never revved past 7000RPM because I had Hondata #4. Make sure you recheck the gray injector wires. Check all the wiring.
Discussion Starter #6
Thanks for the help, we've already found one loose wire. Anyone know what the yellow wire is for?
Vendor
How do you know it is running lean?
Discussion Starter #8
under full throttle, the air fuel guage is deep in the red, i drove it to work this morning after rewiring a few things and it was fine, we are going to soder the wires tonight and hook up the boost guage and i think it will run fine.
Vendor
I sincerely hope that you do not have the air fuel gauge connected up to the front oxygen sensor. If you do, then remove it - immediately.
The front oxygen sensor is a wideband sensor which is current based, not voltage based. Hooking up an AF gauge designed for an early model Honda will screw it up.
Always use the rear O2 sensor for any such gauges.
that was probably your problem..I recommend soldering any connection that you are adding to your vehicle.. :thumbsup:
Hopefully no damage has been done!
Discussion Starter #12
i dont think anything was damaged, i was extremely easy on it the whole time. That was the problem though and it's fixed and running strong. Thanks for everyone's help
1 - 12 of 12 Posts
