1 - 10 of 10 Posts
Click here for hoosier tires in a 225/45/17 this is what size street tire i run, and im have my turbo installed in a month. why would you go with these tires instead of converting to a 15" wheel.
And what would you need to convert to a 15" wheel other than a 15" wheel.
search
all you have to do is search there a lot of threads about ur topic(i think), if not wait for a reply from someone else. i do know for sure if you have a type-s you have to shave some of the calipers. peace
Gothic Hippie RSX tuner?
Base brakes for 15".
TeamDC5
8.5/23/15 MH racemaster slick mounted on a 15x8 drag wheel (5.5 inch backspacing).
TeamDC5
RSXn Mo said:
sorry but what does 5.5 inch backspacing mean
the distance from where the lugs on the wheel are (where they mount), to the back end of the wheel where it drops off..so basically the inner width of the wheel
Otherwise known as offset...? LOL
TeamDC5
yes offeset, but backspacing is easier to understand..as more people are more familiar with inches compared to mm. Also offest is used with regular wheels and backspacing is used with drag wheels,etc.
1 - 10 of 10 Posts
