1 - 4 of 4 Posts
· Registered
I assume you broke the connector off the wire? A quick Google search isn't yeilding the corret results. Best bet would to check your local junk yards for that.
Or if you are handy with a pair of pliers, you could bend up a female spade connector into a circle, attach it back to the wire and plug it on the new sensor. It is a single wire pressure sensor, right?
1 - 4 of 4 Posts
