1 - 8 of 8 Posts
did only the Type S had the front brace and the base didn't?
looking for OEM base front strut bar.
shipped to 94102 can pick up if ur in SF bay area.
The base model doesn’t have the required studs on the strut towers, or the brackets on the firewall. Aftermarket bars will bolt onto the strut towers via the strut mount threads.
ah ok, i was going remove the aftermarket one that last owner put on and get oem, now i can just take the aftermarket one off and not worry about it.
nope, just in the way of the airbox when i want to change the filter. don't want to remove it everytime i clean out the reusable filter.
It's easy to install studs/bolts on the strut tower to accommodate the bar, however, you will also need Type S brackets to bolt up on the firewall. I did this to my base and works perfect.
1 - 8 of 8 Posts
