1 - 8 of 8 Posts
Got Stinkhole?
So did the DIY tail lights, they fine except I know I scratched my tail light underneath...its gonna look like shit when they vinyl eventually wears out and needs to be replaced. FYI for future red out folks....buy the precut ones and do not take an exacto knife to your tail light, chances are you will cut your light!!!
Any one know any way to minmize the effect of a knife blade in tail light? :shakehead
by not giving a shit
My Brain is broken
wetsand them
but unless you cut it 1/8" in and all the way across who cares
Got Stinkhole?
wet sand...hmmm, that won't make the lens all hazy? No the scratches are def there but not no 8th of an inch.
My Brain is broken
not if you use a high enough grit
Got Stinkhole?
Can you explain procedure? Been looking online but all applications are for car paint. Higher grit = higher number? any particular number?
Got Stinkhole?
Discussion Starter · #8 ·
Yes, wet sanding worked...used 1000 and 2000 grit sandpaper, finished off with meguiars pastic x (sp) looks awesome.
1 - 8 of 8 Posts
