Need help finding where part is
1 reading
179 views 2 replies 3 participants last post by  Baileysims
#1 ·
Hi,
I have 2002 base, manual
I was replacing starter, and after putting everything back I ended up with this hose. After starting a car, it keeps reving up after it warms up, which might indicate the problems with the vacuum lines.
I am not sure where this hose goes, and any suggestions would be appreciated!
Thank you!
#2 ·
welcome to the forum
IF did you do the work or someone else offered a hand doing it?
There should not be a hose in your hand if you did it. The tube looks to have a "check-valve" by the ways.
If the line was a vacuum line it would be making all kinds of fuss.
If it is the line or part of that line, your brake booster requires a check valve to operate.
