next to the radiator cap?
cap radiator
3.8K views 11 replies 5 participants last post by  rsxmachine
#1 ·
what is that liquid bottle next to the radiator cap???? it seems mine is getting low and needs to be refilled but dont know what it is...
thanks:thumbsup:
#7 ·
do not use the radiator to put coolant in. use that clear tank that you circled to put coolant inside.
you put a risk to yourself by putting coolant through the radiator when it is hot.
just buy a bottle of coolant.. mix the proper amount of distilled water in it then pour it in that clear tank. it should be between min and max.
#10 ·
i knew that i dont put the coolant in the radiator...:thumbsup:
trust,
that premixed antifreeze thingy...does that mean i dont have to put 50% water and 50% coolant????
