Yesterday I was trying to adjust my clutch pedal on my 2002 RSX type-S before I touched anything with my clutch I went to check the slave cylinder I pressed it in a few times “unknowingly letting air into the system” as my friend told me so I went to bleed to slave cylinder at this point the pedal is completely dead 0 hydronic pressure so I bought a pressure bleeder that you connect to the valve I tried and tried to bleed it and it would force and air or fluid out I’m stuck on how to bleed the CMC and tips and help would be appreciated thanks guys 👍
