RSX Axles (Base vs Type S/R)
19K views 3 replies 4 participants last post by  Hyoriu
#1 ·
Hi all,
I am about to upgrade to Insane shaft 500hp rating axle. There are two different type, Base or Type S.
Further searching on the net found Base RSX axle is 32mm in size whereas Type S/R uses 36mm in size.
Can I just basically buy Type S axle (bigger size 36mm), then only change the spindle hub to type S whilst retain all the Base's brake?
Cheers for input.
