Stock fuel pumps base vs type-s
13K views 11 replies 4 participants last post by  Nicolas22S
#1 ·
Hi Guys!! First post, after searching of course.
My fuel pump is leaking. I need a new one.
What's the difference between the Factory Stock Fuel Pumps in the Base vs. the Type-S?
Acura dealership lists 2 different part numbers.
Base = 17045-S6M-A01
Type-S = 17045-S6M-A30
Every aftermarket parts store lists them as the same part number and say they are interchangeable. I.E. ~ Advanced, O'Reilly, Napa.
I have a pretty mint all stock 06 Type-S with 112k miles and I don't want to overpay for the Factory Type-S fuel pump if it makes no difference.
Napa sells the interchangeable pump for $212.
Acura sells a type-s pump for $415
Any one have any facts or opinions?
THANKS!!!!!!!!
#2 ·
Honda doesn't usually create new part numbers for no reason. It could be something major, as in flow characteristics of the pump, or it could be something minor, like a different cast of a tiny plastic piece.
If you're hurting for cash, I'm sure the Napa one will work fine. If you want that extra peace of mind, get the correct part from Acura.
I replaced mine recently with the OEM part, from an online Acura dealership for less than $300. Probably was Delray or acuraoemparts.org
#3 ·
2 of the closest dealerships to me say the typeS pumps are no longer available.
They say they can try to get it but I need to pre pay in person and they dont know how long if ever it will come in. I dont want to drive an hour away for disappointment on an if.
Money ain't a problem, I just don't want to waste any if not needed, I really just want the same performance.
Thanks for your reply!!!!
#6 ·
You can get a Walbro for half the Napa. Ebay RSX fuel pump and there is even one for $10. The difference in part # might be the pig tail to connect it. There is only two wires so it's a pretty easy task if you need to swap your pig tail. Problem nowadays is there all probably the $10 one and would work as long as the OE. Nothing magical about the Chinese factory that made the Honda pump.
#7 ·
I suppose that depends on if the pump died, or if the housing is cracked and leaking gas. In my case, it was not the pump itself, but the plastic housing leaking gas onto the top of the tank. I've had a Walbro die on me within 2 weeks, and another I had for 5+ years, so I can't say much good or bad about them.
#12 ·
I’m having the same issue right here, I have an 06 type s but I’m wondering if the base would fit and work the same way the “type s “ pump would I’m no trying to overpay for this and I’ve seen them for around 260, does anybody knows where can I get it a little cheap ?
