NEW PARTS PURCHASED : 6/8/2022
Hello clubrsx.com this is the 1st time I have ever created a build thread, not just on clubrsx.com but on any website.Some history on this thread : I purchased this 2002 Acura RSX Type S a few years ago. It was 100% bone stock, zero aftermarket modifications done, and it was a one owner of a 56 year old man primarily used for highway travel as a DD to work. The car came with the original window sale sticker, the maintenance reports from the dealership service department, original literature packets, original leather travel notebook provided by the dealership, and even an Acura pen with business card of the car's salesman.
The car was turned over to me at 142,000 miles, burned little to zero oil, and came with a strong engine. The tranny has zero pop-outs, grinds, hesitations, and shifts like butter. The dealership installed the oem LSD and I must say did a fine job keeping the engine, tranny, and chassis up to par. The only things wrong with the car is the door locks have to be done manual, the rear taillight gaskets needed to be replaced, and there are a few minor dings in the body. At some point I would like to repaint the car in a few years when I can afford a quality repaint. I would love Championship White though I will settle for it's original color. This build thread is being done to the best of my ability and will provide as many (part numbers) as possible.
Currently the purpose of this build is to get as many miles out of this engine and tranny, providing I add some love into the build. It will be going to my daughter soon. I am REPLACING the Timing System, Oil System, most Mechanical Systems, Gaskets, O-Rings, Bolts, Valvetrain Assembly, and UPGRADING Camshafts, Bolt-Ons, Fuel System, Cooling System, Exhaust System, and Engine Management.
I am slowly reworking the exterior and so far I have ordered a INGS front lip, PCI 4" side skirts, and I have not decided on a rear lip. I need to replace the rear bumper because some douche bag did a hit and run bang up job on me, not crazy damage. I would like to see the new front lip and side skirts installed to get an idea what would line up best with the PCI side skirts. I really like the oem 2002-2004 Type R rear lip, it just looks best. I do not need a lip that hangs low because of aero drag.
I am big on oem parts. I am big on mechanical upgrades. My love for road course racing developed in the early 2000's when I got involved in SCAA/NASA schooling (Hyperfest Weekends).
Engine
4Piston Performace Rebuild PRB-1 Service
Engine
- 2002 K20A2 Bone Stock Longblock
- Hasport 62A Engine Mounts Driverside & Passenger Side
- Hasport 70A Front & Rear Engine Mounts
- 2002 K20A2 4.3FD 6spd, Oem JDM DC5-R LSD
- K-Tuned Billet Aluminum Shifter Bushings (KTD-CAB-SPH)
- H&R 20mm wheel spacers (4065640)
- Suspension
- K-Tuned Rear Lower Control Arms (KTD-RL)
- SPC Rear Upper Camber Arms (67230)
- SPC Front Camber Bolts (81280)
- 05-06 OEM DC5-S 26.4mm Front Sway Bar (51300-S6M-A51)
- Hardrace 26mm front sway bar bushings (6266)
- 05-06 OEM DC5-S 21mm Rear Sway Bar (52300-S6M-A61)
- Hardrace 21mm rear sway bar bushings (6911)
- Hotchkis Front & Rear Sway Bar End Links (2540)
- Megan Rear Lower Adj. Tie Bar (0788536944240)
- Interior
- Honda jdm DC5-R Shift Knob (54102-S6M-R00)
- Honda jdm DC5-R shift Knob Backing Nut (90310-ST7-Z00)
- Weight Reductions
- Spare Tire (28.6lbs)
- Jack & Tool Kit (5-6lbs)
- Rear Seats Delete (35lbs)
- Rear Seat Belt Delete (12lbs)
- Rear Cargo Screen (3.5lbs)
- All Interior Carpet (13lbs)
- firewall carpet (10lbs)
- All Plastic Trim Below Windows (18lbs)
- Oem Airbox Assembly (11lbs)
- Cruise Control Assembly (4-5lbs)
- AC compressor, AC piping, AC blower asssmebly, AC Intercooler (30lbs)
- Rear Lower Control Arms Minus K-Tuned Arms (3.2lbs)
- Center Console Delete (5lbs)
- Bose Head Unit (7.5lbs)
- Bose AMP (2.3lbs)
- Bose Subwoofer (6.8lbs)
- All Four Speakers (3.2lbs)
- Oem Cat Delete (17lbs)
- Intake Manifold Support (1-2lbs)
- Soundproof Material (30-35lbs)
- Hood Liner (3.5lbs)
- Glovebox (3lbs)
- DC5-S Front Leather Seats vs Cloth (12lbs)
- Aluminum Lug Nuts (?)
- Chassis Strengthening
- 05-06 oem DC5-S Front Upper Strut Bar (74180-S6M-L50) ** Modified**
- Chromoly 1.25" pipe upper front strut bar Adjustable
- Custom fabricated Lower A-Pillar, Lower Firewall Braces ** Modified from a steel DC5 Type S B-Pillar Mid Bar**
- OEM JDM Aluminum DC5 Type R Lower B-Pillar Mid Brace
- Radiator Housing & Vertical Bulkhead Stitch Welded w/ Bulkhead Bracing
- Chassis kicker bracing at front subframe mount areas
- Custom Race shock absorber/fender bracing
- heavy chassis gussets added at lower B-pillar, Aluminum schedule 80 pipe bracing to upper B-Pillars> Lower B-Pillars> Rear Upper Strut Towers> Rear Gusseting added> Rear Chassis Brace added (this is the plan)
- Stitch welding Throughout & Typically Repeated Areas and Obvious Weak Areas
All New Parts Purchased After 7/1/20 For B&B Build
- Ferrea 6000 Competition Valves ( In. & Ex.)
- Manganese Bronze Valve Guides
- Valve Seats re-cut/ head milled (0.4 compression +)
- Drag Cartel DIC
- Supertech Ti Retainers
- F20C1 Outer Valve Springs (New)
- K20a2 PRB Inner Valve Springs (used)
- Inline Pro Timing Chain Tensioner
- Toda Heavy Duty Timing Chain
- 2007 K20Z3 upper Guide B Chain Guide PN# (14540-RAA-A02)
- Honda (12x47) flange bolt PN# (90032-PNA-000) (In. cam & VTC gear bolt)
- Honda (10x32) flange bolt PN# (90042-PNA-003) (Ex. cam & cam gear bolt)
- Honda Cam Pulse Plate PN# (14113-PNA-003) (In. cam side)
- Honda TDC Pulse Plate PN# (14114-PNA-003) (Ex. cam side)
- Honda Sealing Bolt (14mm) PN# (14115-PNA-000) (x2) ( In. & Ex. cams)
- Honda oem PRB Oil Pump (15100-PRB-A01)
- Honda jdm 02-06 DC5-R Oil Dip Stick (15650-PRC-004)
- Honda oem jdm DC5-R Crankpulley (13810-PRC-003)
- Honda oem Crank Pulse Plate (13622-PNA-003)
- 05-06 Honda oem Intake Camshaft (14110-PRC-030)
- 05-06 Honda oem Intake VTC Cam Gear (14310-PRC-003)
- 05-06 Honda oem Exhaust Camshaft (14120-PRC-030)
- 05-06 Honda oem Exhaust Cam Gear (14210-PRB-A00)
- Honda oem Valve Cotters (14781-PRB-A02)
- Honda oem Valve Stem Seal A (12210-PZ1-004)
- Honda oem Valve Stem Seal B (12211-PZ1-004)
- Honda oem Valve Spring Retainers (14765-PRB-A01)
- Honda oem TDC Camshaft Sensor (x2) (37510-PNB-003)
- Honda oem Crankshaft Seal (43x58x7) (91212-PNC-004)
- Honda oem Chaincase O-Ring (91302-PNA-004)
- Honda oem Camshaft Sensor O-Ring (15x1.9) (91333-PNA-003)
- ARP Head Studs (ARP-208-4701)
- Honda oem Oil Chain (64L) (13441-PCX-004) (back-up)
- Honda oem Oil Chain Guide (13460-PNC-004)
- Honda oem Oil Chain Shaft Tensioner (13450-RAA-A02)
- Drag Cartel Chain Guide (DC-LWR-GUD)
- Honda oem PRB TCT (14510-PRB-A01) (back-up)
- Honda oem Cam Chain Tensioner Arm Guide (14520-PNA-003)
- Honda oem Cam Chain Guide A (14530-PNA-003)
- Honda oem Cam Chain Guide B (14540-PRB-A01)
- Honda oem Cam Chain Tensioner Bolt (90003-PNA-000)
- Honda oem Oil Seal (43x58x7) (Nok) (91212-PNC-003)
- Honda oem Knock Sensor (30530-PRB-A01)
- Honda oem Oil Pressure Switch (37240-PTO-014)
- Honda oem Block Drain Sealing Washers (28mm) (x2) (90401-PR4-000)
- Honda oem Valve Cover Gasket (12341-RTA-000)
- Honda oem Valve Cover Washers (90441-PNA-010)
- Honda oem Cap Nuts (6mm) (90213-PH3-000)
- Honda oem Spark Plug Seals (30522-PFB-007)
- Honda oem Oil Cap O-Ring (15613-PC6-000)
- Honda oem Coil Packs (30520-RRA-007)
- Honda Denso Spark Plugs (SK22PR-M11S)
- Honda oem VTC Oil Control Valve Assembly (15830-RBB-003)
- Honda oem VTC O.C.V.A. Sealing O-Ring (15832-PNA-023)
- Honda oem VTC Filter Assembly (15845-RAA-A01)
- Honda oem VTEC Spool Valve Assembly (15810-PRB-A03)
- K-Tuned P.S. Relocation Kit (KTD-PSP-204)
- K-Tuned K-series Side Mount Pulley (KTD-SMP-K20)
- Hasport Steel Front Engine Mount (62A) (HP-DC5FRM)
- Hasport Billet Rear Engine Mount (70A) (DC5RR-62A)
- Hasport Billet Left Hand Mount (62A) (DC5LH-62A)
- Blox Oil Filter Relocation Kit (BXSS-)
- Exhaust Venturi Vacuum Fitting for PCV Assembly
- Hybrid Racing Silicone Oil Cooler Hoses (HYB-OCH-01-05)
- K-Tuned Billet Shifter Arm (KTD-BIL-ARM)
- K-Tuned Clutch Slave Cylinder (KTD-CLK-KSS)
- K-Tuned SS Clutch Line W/ Fittings (KTD-CLK-001)
- Honda oem Shifter Cable Wire Washer Assembly (54118-S10-000)
- Honda oem Split Pin (2.0x22) (94201-20220)
- Honda oem Split Pin (2.0x35) (94201-20350)
- Hybrid-Racing Race Spec Shifter Cables (HYB-SCA-01-05)
- Hybrid-Racing Heavy Duty Honda Transmission Detent Springs (HYB-DTS-01-03)
- Honda jdm DC5-R Chromoly 10.4lb Flywheel (22100-PRC-003)
- Honda oem Flywheel Bolts (12mm) (90011-PNA-B00)
- Honda oem Clutch Bushing (21x24x8) (22103-PNA-004)
- Exedy Stage 1 Clutch (KHC10)
- Honda oem Passenger Axle Seal (35x58x8) (Nok) (91206-PL3-003)
- Honda oem Driver Axle Seal (40x56x8) (Arai) (91205-PL3-B01)
- Honda oem Shift Arm Cover (24479-PPP-000)
- Honda oem Select Stopper Plate (24467-PPP-000)
- Honda oem Trans Cap Breather (21396-P20-000)
- Buddy Club Racing Spec Quick Shift (BC08-RSS-H004) 40-50% Improvement. Modified With PRB Type S bearings to run K-Tuned Billet Shifter Arm w/ upgraded spring
- MTEC Industries Race Shifter Springs w/ Pivot Ball
- Hybrid Racing Detent Springs w/ new OEM hardware
- BC Racing BR Type Coilovers 30-Way, Adj. Camber Tophats (01-06 Acura DC-5)
- Energy Suspension Master Bushing Set (16-18111)
- Hardrace Extended Roll Center Adjusters 12mm (6476)
- Hardrace Rear Knuckle Hard Bushings
- K-Tuned Adjustable Inner Tie Rod Arms (KTD-TRI-RCI)
- SHG Steering Rack Limited Locking Slider (SHG.P.RACKSLIDELL)
- Honda oem Tie Rod Lock Washer (53536-S5A-900)
- Honda oem Steering Box Mounting A Bushing (53685-S5A)
- Honda oem Steering Gear Box Mounting Box (53685-SL0-A00)
- Hardrace Outer Tie Rods (8144)
- Honda oem Steering Box Mounting (53685-S6M-000)
- Blox Racing Subframe Rigid Collar Kit (BXSS-20603)
- PLM Rear Subframe Rigid Collars
- Honda oem Subframe Bolts (90175-S5A-000)
- Honda oem P.S. Rack Bracket Bolts (90455-S5A-003)
- Mugen P.S. Hard Bushings 6pc. (53685-XK5-S0N0)
- Progress Front 27mm solid sway bar
- Progress Rear 24mm solid sway bar subframe brace kit
- 05-06 Type S Front 26.4mm hollow sway bar
- 05-06 Type S Rear 21mm solid sway bar
- Hondata IMG (Angle Cut To Match PRB Head & RBC IM) (K20A-IMG)
- B&B Performance Modified RBC IM (17100-RRB-A00)
- K-Tuned 70mm TB Tapered to 74mm ID (KTD-70K-DBP)
- K-Tuned TPS Hall Effect (KTD-TPS-HES)
- K-Tuned RBC 70mm TB Thermal Gasket (KTG-RBC-TB)
- Honda oem Map Sensor (37830-PGK-A01)
- Honda oem Map Sensor O-Ring (37835-PGK-A01)
- Honda oem Map Sensor Screw Washer (5x20) (93892-05020-08)
- Honda oem IVAC Rotary Air Control Valve Set (16022-PRB-A02)
- Honda oem Purge Control Solenoid Valve Assembly (36162-PNC-005)
- Honda oem P.C.S.V.A. O-Ring (36221-PNC-005)
- Honda oem P.C.S.V.A. Screw Washer (93892-05012-08)
- Aluminum 3" Schedule XX Pipe Bored to 74mm ID
- Custom Aluminum 74mm ID x 3.325" ID Concentric Reducer (RC-4042-A)
- K-Tuned 3.5" Velocity Stack Filter Combo (KTD-VST-C35)
- K-Tuned Intake Air Temp Sensor Adapter Weld Fitting (KTD-IAT-ADA)
- 3.5" Aluminum (1/8" wall thickness) Intake Tubing, 24" long
- 3.5" Aluminum (1/8" wall thickness) 180deg Extra Long Radius, 24" length
- Mishimoto 3" Coupler black (MMCP-30SBK)
- 2017 Honda Civic Type R Hood Air In Assembly (74160-TGH-A00ZD)
- SSR RSX 421 SS Header
- Honda oem Header Gasket (18115-PNB-003)
- Vibrant SS 2.5" V-Band Clamp (VPE-1490)
- Burns Stainless Megaphone 2.5" In, 4.5" Out, 14.5" OAL, 8deg 304SS (MEG25045SS) *** It is being cut at 3.5" DIA in length4
- Burns Stainless Short Transition 304SS 4" to 3" (RD-300-16-304-S)
- Vibrant 3" x 6" Long SS Flex W/ Braided Liner (VPE-63006)
- Summit Racing 3" SS Premium V-Band Clamp (x2) (SUM-697300)
- Summit Racing 3" 409SS by 48" long Exhaust Tubing (SUM-640130-1)
- Summit Racing 3" 180deg Bend 6" Radius, 10.75" Legs Tube (SUM-622005-SS)
- Vibrant 3" SS Ultra Quite Straight-Thru Resinator (VPE-1142)
- Vibrant 3" SS Stealth Straight-Thru Muffler (VPE-1147)
- Vibrant 45deg Oxygen Sensor (x2) (VPE-1193A)
- Summit Racing SS Exhaust Hanger Hardware (x8) (WLK-35411)
- Acura RDX 410cc Fuel Injector Assemblies (16450-RWC-A01)
- Acura RDX Injector Clips (16451-PLC-000)
- K-Tuned RDX Injector Clips & Pigtails (KTD-RDX-CB)
- AEM 340lph Fuel Pump (50-1000)
- Fuelab Fuel Filter, 40 Micron SS Element, -6AN Inlet/Outlet (81811-1)
- Vibrant Inline 3pc. Fuel Filter Set -6AN (VPE-16736)
- Vibrant -6AN Check Valve (VPE-11187)
- Vibrant Alum -6AN ORB Slimline Port Plug (VPE-10992)
- Vibrant -6AN Flare x -6AN Straight Cut (x2) (VPE-16826)
- Vibrant -6AN 90deg Swivel Hose End (x4) (VPE-21906)
- Vibrant -6AN Straight Swivel Hose End (x7) (VPE-21006)
- Vibrant -6AN Union (x3) (VPE-10702)
- K-Tuned -6AN to 1/4" Female EFI (KTD-14-EFI)
- Vibrant -6AN (0.34"ID) 10' Black Nylon Braided Flex Race Hose (VPE-11966)
- Vibrant -6AN x 3/8" female Quick Disconnect (VPE-16886) fuel tank supply conversn
- Mishimoto Inline Water Temp Sensor Housing 32mm (MMWHS-32-BK)
- Mishimoto 32mm Radiator Cap Housing Aluminum Weld Fitting (MMFN-S)
- Mishimoto 1.3 Bar Radiator Cap (MMRC-13-SM)
- Speed Factory Tuck Radiator (SF-06-TuckedRad)
- Speed Factory Tuck Radiator -16AN Hoses & -16AN fitting package (SF-04-048)
- K-Tuned Swivel Neck Thermostat (KST-UNV-16A)
- K-Tuned Coolant Temp Sensor Fitting Port (KTS-GF-307)
- Summit Racing EPDM Silicone Radiator Hose 90deg 5" legs (SUM-294040)
- Summit Racing EPDM Silicone Radiator Hose 90deg 5" legs (SUM-295040)
- EBC Ultimax Front Rotors
- EBC Premium Rear Rotors (RK7128)
- EBC Green Front Brake Pads (DP21254)
- EBC Yellow Rear Brake Pads
- Stoptech SS Front Brake Lines (805890389774)
- Stoptech SS Rear Brake Lines (90540502)
- Autometer Oil Pressure Gauge, 0-100psi, Ultra-Lite (105-4321)
- Autometer Water Temp Gauge, 100-250degF, Ultra-Lite (105-4337)
- Autometer Oil Temp Gauge
- Autometer Voltage Gauge
- Autometer Intake Temp Sensor Gauge
- Odyssey PC680 Battery Metal Jacket (0769-2017)
- Keep It Clean Battery Kill Switch (KCW-10639)
- Odyssey Universal Terminals (3217-0006)
- Honda oem Water Pump (19200-PRB-A01)
- Honda oem Water Pump Gasket (19222-PRB-A01)
- Summit Racing -16AN Male Aluminum Weld In Bung (SUM-220064)
- Earls -10AN Male Aluminum Weld Fitting (x7) (EAR-997110ERL)
- Earls -6AN Male Aluminum Weld Fitting (x2) (EAR-997106ERL)
- Summit Racing -6AN Male Steel Weld Bung (x2) (SUM-220023)
- Vibrant 3/8" ID Hose Barbed Weld On Bung (x2) (VPE-11181)
- Moroso -16AN ORB x 1.25" Hose Aluminum Fitting (63521)
- Moroso 3/8" NPT Female Aluminum Weld Bung (68900)
- Summit Racing -10AN 45deg Twist-Tite Barb Hose (x2) (SUM-220708-N)
- K-Motor -10AN x M14x1.5 PCV Delete Fitting (CS-60AR-4SZD)
- Honda oem PCV Valve (17130-PRB-A01)
- Aeroflow M14 x 1.5 Aluminum Weld Bung (x2)
- Honda Drain Plug Washer (14mm) (94109-14000)
- Vibrant 3/4" ID Barbed Hose Aluminum Weld On Bung (x3) (VPE-11184)
- Vibrant -10AN (0.56"ID) 10' Black Nylon Braided Flex Race Hose (VPE-11970)
- Honda oem Power Steering Oil Tank Bracket (53777-S6M-000)
- Speedmaster 2.20" dia x 0.7" depth Push-In Air Cleaner (PCE104-1090)
- Wildside Composites Carbon Fiber Sheet (26" L x 14.5" W x 0.09" T) (WSO-WS9033)
- Fragolia # 16 x 1 - 5/16 - 16AN (16) (495119-BL)
- Amazon $75 K20 Upper Coolant Housing W/ Filler Neck & -16AN (KP57901)
No code has to be inserted here.
- Vibrant (#22904) 4AN push on 90deg swivel hose end (qty. 2)
- Aeroquip (#AER-FBM2002) 4AN x 1/4" NPT adaptor (qty. 1)
- Summit Racing (#SUM-220451B) 4AN x 1/4" NPT 90deg elbow (qty. 1)
- K-Tuned 6AN x 1/4" female EFI (qty. 1)
- Vibrant 6AN x 3/8" female quick disconnect (qty. 2)
- Vibrant (#21906) 6AN 90deg swivel hose end (qty. 5)
- Vibrant (#21006) 6AN straight hose end (qty. 7)
- Vibrant (#10702) 6AN union (qty. 3)
- Vibrant (#10732) 6AN female 90deg union (qty. 1)
- Vibrant (#10792) 6AN Tee (qty. 1)
- Vibrant (#16746) 6AN shut-off valve (qty. 2)
- Vibrant (#26002) 6AN hose x 3/8" NPT male hose end (qty. 1)
- Summit Racing (#SUM-220675B) 6AN gauge adapter (qty. 1)
- Vibrant (#11533) 8AN male banjo M12 x 1.5 bolt (qty. 1)
- Vibrant (#11187) 8AN gas check valve (qty. 1)
- Vibrant (#11190) 8AN male check valve (qty.1)
- Vibrant (#21008) 8AN staight swivel hose end (qty. 4)
- Vibrant (#21408) 8AN 45deg swivel hose end (qty. 2)
- Vibrant (#26004) 8AN hose x 3/8" NPT male straight hose (qty. 1)
- Russel (#610175) 8AN 90deg swivel hose end (qty. 1)
- Vibrant (#22010) 10AN push on straight swivel hose end (qty. 5)
- Vibrant (#22910) 10AN push on 90deg swivel hose end (qty. 5)
- Vibrant (#10715) 12AN female 45deg union elbow (qty. 2)
- Vibrant (#24012) 12AN hose x 12AN male hose end (qty. 2
- Vibrant (#16841) 12AN flare x 12AN straight cut O-ring (qty. 3)
- Vibrant (#11181) 3/8" ID barbed weld-on (qty. 2)
- Vibrant (#11184) 3/4" ID barbed weld-on (qty. 3)
- Earl's Aluminum 6AN weld-o-let (qty. 7)
- Earl's Aluminum 8AN weld-o-let (qty. 3)
- Earl's Aluminum 10AN weld-o-let (qty. 6)
- All Star Steel 6AN weld-o-let (qty. 4)
- Moroso (#68900) 3/8" NPT Aluminum weld-o-let (qty. 2)
- Odyssey PC680 Metal Jacket 15lb Battery (8lbs)
- Honda jdm DC5-R Aluminum Front Control Arms
- Honda oem DC5-R Aluminum Front Bumper (7lbs)
- Honda oem DC5-R Aluminum Rear Bumper (9lbs)
- Sound Deadening Removal
- SS Feeler Gauges 0.03 mm - 1 mm (HT0868)
- Clockwise Tools Digital Indicator 0 - 1" / 25.4 mm (DIGR-0105)
- Honda HN Moly Paste (M77) 2.65 oz. (08798-9013)
- SPC Valve seal install punch
- Versa Chem Connector & Spark Plug Boot Grease 0.25 oz. (15309)
- Honda 5999 Ultra Flange II 4 oz. (08718-0009)
- Hondabond HT 1.9 oz. (x2) (08718-0004)
- Cyclo Dielectric Grease 3 oz. (C-706)
- Imperial Tube Bender Triple Head Head 180 deg (470FH)
- VHT High Temp Wrinkle Plus 11 oz.
