VVT Solenoid
3.5K views 3 replies 2 participants last post by  Manhole17
#1 ·
I had a P2646 rocker arm actuator system performance/stuck code. The car would not go above 4000 RPMs. I replaced the VVT solenoid and it made no difference at all. The oil was changed with the right oil and I always use the right oil, I don’t know what to do next.
Any suggestions would be much appreciated. Thank you.
#2 ·
Is the pressure switch new as well? Pretty sure this CEL is specifically related to the switch rather than the solenoid. Also check if the vtc strainer is clogged. It’s on the left side of the head behind the PS pump.
By the way, it’s called a Vtec solenoid 😉
#3 ·
I replaced the whole unit, so the switch is also new. The screen on the old unit was clean. I cleared the code, went for a short ride and the problem and code are back. I’ll check the wire to the switch. Other than that I don’t know what to do next. Thanks.
#4 ·
Go to the link below and download a copy of the service manual. There’s trouble shooting steps to check the wiring as well as the oil pressure.
