ITR ecu question/problem
574 views 5 replies 4 participants last post by  ekk20sir
#1 · (Edited)
CEL questions
problem solved , o2 sensor circuit issue
thanks
#5 ·
if your front o2 sensor is bad the O2 will go into limp mode. Its backfiring because its running so rich to protect the motor. In limp mode the engine rev limits and adds a ton of fuel to save the engine. Replace the front o2 sensor with a new one, and reset the ECU you'll be set.
