RBB Install
install rbb
1 reading
9.5K views 7 replies 3 participants last post by  fatso666
#1 · (Edited)
Hey guys, i bought a RBB Manifold (TSX 04-05) to try it on my RSX i was looking for some DIY but seems like there's nothing.
Anyone can advise about how to install it on the K20A2 head?
What i researched so far, in order to install the RBB Manifold in the K20A2 head you have to:
  • Extend brake booster line
  • Extend PVC vaccum line
  • Same Cut like RBC
  • Weld the hole after you cut like the RBC
  • Replace the fuel rail with an aftermarket since the OEM with the middle regulator won't fit
  • You have to use an RBC\RBB Throttle body adapter in order to user your cable TB
  • Use only the RBB from the TSX 04-05 because it still has the IACV passage the 06-08 doesn't
i WILL UPDATE MY FINDINGS AND THIS CAN BE A DIY IN THE FUTURE
#4 ·
#6 ·
#8 · (Edited)
Yes you are correct the one tested was ported by ENDYN but he was using a stock 62-64mm TB, i going to use 2006 TSX Cams and bore mine to 70mm and use a 70mm TB. Maybe if i can't reach 11ftq at least i can get 8ftq. Currently i have a PRC but i want more torque.
