Type-S turbo Vs Base turbo
5.8K views 38 replies 17 participants last post by  aznbeayst
#1 ·
Which would be better in sence of durability, power, and longevity (spelled the wrong)????????
#2 ·
This would be interesting to know, espcially that the Type-S has a high compression ratio...
#7 ·
crazy said:
The Type R runs the highest compression right? The Top Fuel DC5-R (turbo) gets 493 WHP (it has a bore and stroker kit giving it 2.4L of disp.)....
If it has that, then it probably is running much lower conpression than stock.
#8 ·
Well.. if it is stroked then they replaced the rods and pistons(especially at 493WHP), so they more than likely are running 9:1 or so.
The base has lower compression, but it is like the tegs, LS are good for pushing more PSI stock than say a GS-R or Type R, but the GS-R And Type R usually pushed more power on stock blocks for two reasons. One being better a better flowing head on both engines, two is somewhat iffy. The higher your compression, the more power you make per pound of boost, but it also runs hotter, and takes less boost to melt the pistons etc.
I think...
All in all it depends on where you are going, if you don't want to touch your head, as far as porting/polishing goes, you are better off starting with a type S. Also with a type S comes a higher revving engine, so you can go with a turbo that might spool a little later, and still have a longer rev range that it will be spooled.
#12 ·
Actually, i'm torn between the greddy kit and CN kit...the CN kit is finished but with the greddy kit i can put more parts on as time goes by. It's a hard decision for me...I might just go with the CN kit b/c it has everything that i need...except for the clutch and flywheel which im getting from here. Chris, speaking of trannies, how much power can the organic clutch withstand?
#18 ·
I would think that the type s has the best platform to build on overall for being quick and fast at the same time. The money difference between the cars is minimal, and the base is obviously not up to par suspension and package wise. Since all rsx owners like the overall package of their cars, I would think that they would chose the s. It will eventually be quicker for the money, and like I said, would be a better base platform to work from. Cheaper isn't always better. As for the compression being bad for the engine, that is most likely true if it isn't tuned well, but the rsx-s can probably be made pretty reliable with some sufficient tuning. All of it is time and research, but hopefully not at someone's expense. For me I would go with the better engine flow and more power made by compression and take my chances with reliability since I don't think there would be that much of a difference.
#19 ·
hondacvcjosh: You have a good point for the S being a good platform and it is a great platform to build engine wise and I'm not doubting that. But there are people out there that want to put their heart and everything they got into their car to make theirs unique. I am one of those people, I chose a base for many reasons, and one of those main reasons was that i could build up that car anyway that i see fit. But you can't deny that the base model isnt a good platform b/c it is.
#20 ·
No denying that the base is a good platform, and that it is very refined in relation to most cars. I just said the s was better money and everything else aside. The one thing that would intrigue me about the base that I never quite thought about was the fact that you can be in boost longer for each gear, allowing more spool up time, and possibly giving a little edge to the base in some midrange.
#22 ·
I believe a stage 1 base model RSX puts about close to 270whp while the S is slightly over 270whp, i think 274...so not a BIG difference but still a difference.
hondacvcjosh: and that's exactly why i chose the base model, think about it everyone, longer gears mean what? more time for boost. just raise the rev limiter on the engine and bam! there ya go...
#25 ·
ummmm...are you sure about that??
as much as i'd like to believe it...i have my doubts about only 4whp less than a type-s.
where does the extra 36whp come from??
#26 ·
it's a rough estimate for me, the exact numbers i believe were on the cybernation website...275whp for the type S...i cant find it, but the base model/ep3 puts like 260ish whp i believe, dont quote me on it. You have to remember, lower compression means you can boost more...
