Hey guys,
Just 2 small question.
So I just ordered in a new oil pressure sensor switch since I've been getting the P2647 code.
Well, question one is, do you guys take off the... I think it is called heat shield? That metal plate surrounding the plugs in that area when trying to remove the sensor? Also what is the socket / wrench size for those bolts, anyone here know?
It seems my socket can't physically fit into the old sensor without taking the heat shield off - I know dumb question somewhat. I did purchase a 24mm socket as following this forum and it fits nicely with the new sensor.
Second question is when I removed the female connector clip off the old sensor, the male connectors are still stuck on the old sensor, is this normal? The new sensors I ordered in does not have any sort of male connectors attached so I have no idea if we are supposed to remove the male sensors attached to the old sensors and put them onto the new one? Reason being, if the new one was supposed to already have connectors attached to it and we simply plug in the female side from the engine, I am not sure if I received a faulty product than...
Thanks all for taking the time to check out my thread.
