ASPEC RSX wheels specs
1 reading
19K views 26 replies 15 participants last post by  bsw845
#1 ·
From what I've read, there are 2 different sets of wheels. Maybe 03-04? & 05-06. Regardless, I'm referring to the ones pictured below. I'd like to know the specs of these wheels.
1. Does Acura actually manufacture them
2. Offset
3. OEM tire size
4. Weight
5. Any other pertinent information
Also, what is a possible next wider size tire that will work on the wheel?
Thanks for the (flameless) help whether a direct answer of just pointing me in the right direction...
#4 · (Edited)
they are sold by acura as 02-04 a-spec wheels; 17x7" gun metal. OEM tire size would be 225/45/17. they weigh about 23lbs. 225's are perfect and honda recommended. obviously the next wider would be 235s and that's strongly recommended against. oh and those are enkei J10's. look them up.
#5 ·
they are sold by acura as 02-04 a-spec wheels; gun metal. OEM tire size would be 225/45/17. they weigh about 23lbs. 225's are perfect and honda recommended. obviously the next wider would be 235s and that's strongly recommended against. oh and those are enkei J10's. look them up.
Curious, why are 235s strongly recommended against? Do you mean for this particually rim or for this vehicle?
#8 ·
well you are getting 17x8" wheels for your tires that are 235mm. i would recommend getting 245s or 17x7.5" wheels but i dont know much about these setups. you could still get the 235's for the a-spec wheels but your handling could be jeopardized.
