Ok so if you want to replace your speakers or put in new door cards your gunna need to take the door panel off and this is how ya do it.
Tools
-Small flat head screw driver
-Medium sized philips head screw driver
Step 1
I started with the passenger side first. So role down the window all the way. Pull the tweeter cover off. and unplug the tweeter wire and set the cover tweeter aside.
Step 2
Take your small screw driver and on the back of the door handle there is a small hole. Stick your driver in and push the door pull off.
Then take your small flat head and pry the cover off under the door handle
set that cover aside.
Next you'll be lookin at this
There are 8 screws that you need to take out here so get the philips and start goin at it.
Once you get them all out you can pull the handle and switch off
Then wiggle the handle away from the switch. and unplug the connector from the switch.
Step 3
Now your gunna start pulling the panel off. Start at the front of the door the side closest to the front of car. Get your fingers under and pull. It can be hard but the clips will come out.
Work your way under the door and around the bottom.
Now that all the clips are off you will have to lift the panel up and off the door and the lock. once its off the door
Step 4
The cable for the door handle will be attached
So pull this off
Then pull the cable out of the hole.
Congrats you just took the door panel off! Reinstall the panel from step 4 back to 1.
When reinstalling make sure to put this piece
firmly back into place! i didnt the first time and it came loose as soon as i put the door back together and had to take the panel off to fix it. so make sure of that.
Any questions just PM me.
Tools
Step 1
Step 2
Step 3
Step 4
So pull this off
