Bigbuyer2477 said:
Does the Honda ECU go into open loop depending on TPS or MAP signal?
I would assume that once in open loop the ECU will try to hit it's preprogrammed target values, regardless of the sensor readings. So when you are in open loop, that shouldn't be a problem, right? I think only when you are in closed-loop that's where the "issue" comes up. Can you set the TPS cross-over point in the E-manage?
The hondata K-pro ECU can crossover from closed-loop to open loop on MAP sensor settings. You can make it switchover at will at any value you like, depending on your set-up.
The problem they are having is the fact that with just the emanage and stock ECU alone, you cannot control when the ECU goes into open-loop, thus you cannot control how the ECU reads the load data and gives appropriate fuel, ingnition and cam timing. This can cause lean conditions at partial throttle, which is that hesitation you guys are talking about.....but remember this, you guys are talking about 50%+ throttle...you should not be at part throttle like that, you might as well go WOT..these are not good boost habits. This will insure that the ECU will give the appropriate amount of fuel. With the k-pro, you can have it switch over at a certain boost pressure like 80kPa, or whatever your setup demands from the ECU. This will ensure proper fuel, ignition and cam timing under boost even at partial throttle, thus making this ECU alot safer than just the emanage/stock ECU alone.
