k20a2 head vs k24a2 head?
1 reading
35K views 23 replies 8 participants last post by  EddieIt
#1 ·
So I just wrecked my built k24a4/k20a2 swap. Looking at a used k24a2 long block and wondering if its worth spending the money machining my current head or just saving the money and sticking with the k24a2 head. My old build was a 9:1 compression with stock cams and flat valves so im wondering if I would notice much of a power decrease by just leaving the k24 head on. If anyone knows anything about this I could use the advice. Thanks crsx!
#3 ·
I *think* just from what I've read on here, but you won't be too disappointed with the K24A2 as is, but if you're going to get aftermarket cams, the K20A2 head is better. Why would you have to machine it though? (<-- could reveal my frank noob status :noes:)
#5 ·
The motor was built for boost with blueprint pro I beam rods, je pistons, toda tensioner, bc valves, valve springs and retainers and stock cams. Like I said it was built for boost but it never happened. So basically im just wondering if I'm going to notice a hp/torque decrease just dropping in a full k24a2. I honestly don't think I will seeing as I was 9:1 and the k24a2 is 10.5:1. Oh and basically the toda tensioner failed after only a couple months and the head gasket went which is why the motor is cooked.
#7 ·
Agreed. jumping from that 9:1 compression up to 10+:1 comp [NA] should net you horsepower gains, not losses, regardless of which head you run with (provided you have a proper tune.)
Regarding bricking the engine, TCT failure and Headgasket aren't typically associated with one-another unless you've got some other MAJOR internal damage.
#9 ·
Yeah I have the rbc off my old motor but apparently it won't fit on the k24a2 head? So in that case I probably will just leave the stock rbb manifold on there. And I'm not sure if the tct and head gasket were related just my bad luck.
#13 ·
If the RBC is cut for a k20 head then I believe you're right, it will no longer work with the TSX head. If the RBC isn't cut then I think it should work.
Not really is that the difference between the 05 k24a2 and the 06+ k24a2?
The 06+ TSX has better cams and I believe the intake valves are bigger(not 100% sure about the exhaust valves though). There may have been more updates but this is all I remember. I think the crank may have been improved too.
#14 ·
exhaust cam is the same for 04-08. only intake cam is different. also 06+ has different valve springs and intake valves. exhaust valves are the same for all years. pistons and rods are different. piston rings are same for all years.
#15 ·
In short, the PRB head will out flow the RBB head all day. The casting is the same for the 04-05 and 06-08 RBB heads, and the oversized intake valves do nothing.
Via K20A.org...given the dyno is comparing the FD2 RSP head vs. the RBB 36mm head, it still gives a good comparison between the K20 and K24 style heads.
"Back from the dead with another test on a different motor
2008 stock TSX (longblock) with:
RRC IM, Injen Intake, P2R TB spacer, Header & exhaust
before stock RBB head with stock valves (+1mm oem intake)
after RSP with Ferrea 6000 (std size) valves. Gained 19whp up top! fyi we were able to eliminate the tq dip from 5000-5700 with a stepped intake w/velocity stack. Getting that to fit is another story LOL"
Also, flow charts for most of the K series heads.
http://www.k20a.org/forum/showthread.php?t=107797&page=2
