K20A3 Connecting Rods
1 reading
8.7K views 4 replies 3 participants last post by  Scourge
#1 ·
Whats up I have a 2003 k20a3 base RSX. I have already put a turbonetics turbo kit in it with Kpro, a 3inch kteller exhaust, bigger injectors, short ram intake dual disc clutch ECT. you get the point I have a good amount of money in the car. I'm running currently 10psi and have been for a little over a year which is the max amount of boost those shitty k20a3 connecting rods can handle. I have been looking all over and cant seem to find forged connecting rods that has a center to center distance of 5.4720 IN. with a big end housing bore clearance of 2.0079-2.0087 IN. or in other words forged connecting rod that fits on a stock piston and a stock A3 crank. please don't tell me I should just go buy an A2/Z1 crank because I already know this I'm just short on cash and I'm pulling the motor to do some other work on it and wanted to through the rods in while I have it apart. thanks for the input
#5 ·
Just so you know, K20A3 rods have the same center to center distance (and diameters) as the K20A2, K20A, K20Z1 and K20Z3...
Right now I have a Manley spec sheet with exactly the dimensions you mentioned (Manley part #14404-4). I also had the Eagle info in front of me a few days ago and I'm quite certain it was the same. Can't recall if the wrist pin sizes were bigger or smaller than stock though.
