i have checked almost everything from the throttle body valve to the cables everything looks fine. There are two throttle return springs that i see, one(bigger one) connected to the cruise control and the second (smaller one) for the throttle . the cruise control spring seems to work fine, it moves back and forth in a spiral . the throttle spring however doesnt, its like it broke off or unhooked from the throttle valve, it doesnt move in a spiral or at all, is that normal???
ithas only gotten stuck when im at WOT in 3 gear or higher(high load), i can still actually get the throttle unstuck by stomping on the gas pedal for a couple seconds> Also, when i always go full throttle (even if it doesnt get stuck) sometimes it idles a little high( almost 2000 rpms) and then after cruising for a bit longer it returns to normal(800rpms) . Can anyone help me?thank you
