AEM V2 Intake - Filter question
7.4K views 23 replies 6 participants last post by  IronGumby
#1 ·
Hey guys,
I just bought used AEM V2 Intake set in decent condition, but I have a doubt should I install used filter from the set, or buy new one. In the used one the outer rubber layer is going off (layer under looks ok).
What do you think?
Pics below (click to enlarge):
#4 ·
This post should be with hyperlinks and photos but it still waits for admin approval.
I am now thinking about AEM V2 I have bought...
(My Acura is K20Z1, 2006 Type-S)
When I look at it I cannot find anything similar in AEM RSX Type-S compliant intakes on AEM web page.
The closest one is 24-6105C
But when I open installation sheet, it says: 2002-2006 ACURA RSX - Excludes Type S
As I bought this item used and I cannot really give it back...
The question is:
Is it safe to install this Intake onto my 2006 Acura RSX Type-S K20Z1?
Previous owner successfully used this Intake on similar vehicle without any issues, but I prefer to ask people smarter than me, there might be things I don't consider like air pull capacity, etc etc
I hope I don't damage engine or other components by using it, do I?
:run:
#5 ·
So far as I know... if you can make it fit; it's fine to use.
The base and S models have the Intake Air Temp probe on the opposite sides from each other. The angle of the throttle body input may be slightly different angles. But I'm not sure about that.
So long as you can connect the wires/hoses and make a good connection without any leaks; you're good.
#12 ·
'Tis very interesting! Especially because it has different resonances vs stock (? is that what was before? or an SRI?). But I bet besides the better midrange performance, you will be pulling cooler air in more regularly during daily driving. Well, maybe (forgot it was the V2 for a second)
But do you like how it sounds?! It's gotta be pretty gnarly during VTEC, especially if you reflash it to crossover in the the low-mid 4000's :thumbsup:. By the looks of your flash, I think you did!
#13 ·
Before there was standard intake Comptech Sport, now it looks like this:
I don't see much HP improvement to be honest, but the sound.. Dear Lord! the sound is just amazing. :hb:
Before it was like one sonic boom over 6000rpm when VTEC kicks in; now there are two one around 4500rpm when V2 starts to resonate and then over 6000rpm when V2 adds in.
Now I wonder what was the point of installing MP3 audio if engine sounds much better!
I love it.
Apologize me, I am not native English speaker, what do you mean by: " especially if you reflash it to crossover in the the low-mid 4000's . By the looks of your flash, I think you did!" ?
#14 ·
The AEM V2 should perform similar to the stock intake after being heat soaked. I know it because I have one. The V2 does make the car sound meaner, but doesn't help that the modded car still moves just as slow as stock. LOL. But it does help with gas mileage though.
#15 ·
I love it.
#16 ·
I love it.
#17 ·
Unfortunately I cannot post with pictures as those posts are pending to be approved by admins :(
Before there was standard intake Comptech Sport.
I love it.
#21 ·
I meant to say "by the looks of your graph," but anyways, I was saying it will sound great at the VTEC crossover, which will be great if you reflash the ECU and change it from 5800rpm to something like 4500rpm. But it looks like you already did get a tune/reflash! Because your torque looks good between 4500-5800. I would not expect an intake alone to give you the torque curve you have. So good job! :thumbsup: Enjoy
So yeah basically your V2 intake will sound even better from 4500-5800 on a tune than a stock ECU :]
#24 ·
Well you can check the ECU serial number with Hondata or Ktuner, but you'd be the best one to tell with that super loud intake. Do you hear the VTEC crossover pop at 5800rpm? Or do you hear anything change slightly more throaty/robust at exactly 4000/4200/4900/5200rpm (those are the common crossover points at full throttle).
Did the guy at the dyno say anything? I mean, did he just do some pulls for you, or did you pay him for any tuning? Most stock RSX-S's don't have a torque swell that begins at 5000rpm like you do. Maybe your "CAI" is magic, lol. No, cuz plus your stock fuel cutoff is at 8300rpm so if this dyno is accurate, he pulled through 8600 (reflashed fuel cut)!
