721 - 740 of 740 Posts
Relevant it is. Took my car to Brandsmart to get a sound system installed, and removing the seats tripped the SRS light of course. For some reason the tech couldn't get the code to clear with his scanner and the scanner wouldn't even read the code. He proceeded to waste an hour of his time taking my car to some random shop, without calling me first. I got an alert on my smartstart GPS, and of course when I get to brandsmart I'm able to fix it in 10 seconds. Thanks dude, this trick is da bomb
Discussion starter · #726 ·
Almost 12 years later and this DIY is still relevant. Thanks for keeping the pictures up to date too, this saved me some $$ getting my SRS light 'diagnosed' at a shop.
yeah, the pictures are hosted by my website so as long as my website is still up, the picture will still be there.
Discussion starter · #727 ·
Glad this worked! 10 seconds vs 1 hour... i'd go with 10 seconds lol unless its something sexual then thats a different topic
Damn KSMatic, you're still around! Good to see some OGs still runnin the show around here.
Discussion starter · #729 · (Edited)
Discussion starter · #731 ·
What up guys! Do either of you still have an rsx? I still daily mine, LOL.
lol, sadly.. no. Whats up man, glad you still have your car!
lol, yes. I'm still around.. I just lurk a lot. You should of came to our meet a few weeks ago.. It was a 10 year reunion. Brought the ferrari out and it was powered by FutureITR.. lol This thread : http://forums.clubrsx.com/showthread.php?t=1226241
Lol would be cool, but moved out of Cali.
I still have it but it just parks. :thumbsdow Right now parked pending a TPS and primary o2 sensor :rotfl:
It's on its last legs, but at this point, I don't know if I could get rid of it. 14 years is a long time.
hahah. Where'd you move to?
Thanks, this worked perfectly for me. I had to give it about 10 tries before I got it to get to the 2 quick flashes part. After that the light stayed off.
There were a couple of problems I encountered. First, I used a jumbo paper clip which doesn't fit into the connector at all. I had to hold it to make contact so that made it a bit harder. Second, I wrote down that there would be 3 flashes in the beginning before the SRS would turn off for the first time. I didn't realize it said 3 seconds. If anyone is going by flashes I believe it is 7.
Now I just have my engine and abs light to go through.
Thank you for the post, it's still very helpful.
I tried doing this but the fuse box is very difficult to access. After cranking my neck to the point I need a chiropractor, I finally by a miracle pulled out the SRS plug. But there's no slack whatsoever on that yellow cord so it would be impossible to coordinate putting the paperclip in and out by feel even if I had freakishly long arms. Guess I'm destined to have the SRS light remain on.
How are the rest of you possibly able to manage this? Are you unscrewing the fuse box? Even then the yellow cord is too short to access.
